Handle number of WiFi client connections
snahmad75
Postby snahmad75 » Tue Nov 20, 2018 1:39 pm
I have below method. I keep track of number of WiFi client connections. I run my application both in AP and STA mode. How can I keep track of number of WiFi clients. when last clients gets disconnect. I need to have __num_of_wifi_client == 0.
In AP mode it works fine. but I join another WiFi with STA. Should get called SYSTEM_EVENT_AP_STACONNECTED. If I leave/disconnect from STA. should I get SYSTEM_EVENT_AP_STADISCONNECTED?
Can some one verify. I am getting strange behaviour in STA mode.
uint32_t __num_of_wifi_client = 0;
esp_err_t wifi_manager_event_handler(void *ctx, system_event_t *event)
	switch(event->event_id) {
    case SYSTEM_EVENT_AP_START:
    case SYSTEM_EVENT_AP_STACONNECTED:
		__num_of_wifi_client++;
    case SYSTEM_EVENT_AP_STADISCONNECTED:
		if (__num_of_wifi_client > 0) {
			__num_of_wifi_client--;
    case SYSTEM_EVENT_STA_START:
	case SYSTEM_EVENT_STA_GOT_IP:
	case SYSTEM_EVENT_STA_DISCONNECTED:
	case SYSTEM_EVENT_WIFI_READY:
	case SYSTEM_EVENT_STA_STOP:
	case SYSTEM_EVENT_STA_CONNECTED:
	case SYSTEM_EVENT_STA_LOST_IP:
	case SYSTEM_EVENT_SCAN_DONE:
	case SYSTEM_EVENT_STA_AUTHMODE_CHANGE:
	case SYSTEM_EVENT_AP_STAIPASSIGNED:
	default:
	return ESP_OK;
snahmad75
Re: Handle number of WiFi client connections
Postby snahmad75 » Tue Nov 20, 2018 6:05 pm
Just to add.
I can see when join another access point.
I get SYSTEM_EVENT_STA_CONNECTED followed by SYSTEM_EVENT_AP_STACONNECTED sometime.
Is this normal?
Users browsing this forum: bushpulbek and 132 guests
