I ma doing SD card mount
// Options for mounting the filesystem.
// If format_if_mount_failed is set to true, SD card will be partitioned and
// formatted in case when mounting fails.
esp_vfs_fat_sdmmc_mount_config_t mount_config = {
.format_if_mount_failed = true,
.max_files = 5,
.allocation_unit_size = 16 * 1024
It used my internal ram of 20k after mount. How can I reduce it. I need high number of CONFIG_FATFS_FS_LOCK. Web browser access files simultaneously.
My FATFS config is
# FAT Filesystem support
CONFIG_FATFS_CODEPAGE_DYNAMIC=
CONFIG_FATFS_CODEPAGE_437=y
CONFIG_FATFS_CODEPAGE_720=
CONFIG_FATFS_CODEPAGE_737=
CONFIG_FATFS_CODEPAGE_771=
CONFIG_FATFS_CODEPAGE_775=
CONFIG_FATFS_CODEPAGE_850=
CONFIG_FATFS_CODEPAGE_852=
CONFIG_FATFS_CODEPAGE_855=
CONFIG_FATFS_CODEPAGE_857=
CONFIG_FATFS_CODEPAGE_860=
CONFIG_FATFS_CODEPAGE_861=
CONFIG_FATFS_CODEPAGE_862=
CONFIG_FATFS_CODEPAGE_863=
CONFIG_FATFS_CODEPAGE_864=
CONFIG_FATFS_CODEPAGE_865=
CONFIG_FATFS_CODEPAGE_866=
CONFIG_FATFS_CODEPAGE_869=
CONFIG_FATFS_CODEPAGE_932=
CONFIG_FATFS_CODEPAGE_936=
CONFIG_FATFS_CODEPAGE_949=
CONFIG_FATFS_CODEPAGE_950=
CONFIG_FATFS_CODEPAGE=437
CONFIG_FATFS_LFN_NONE=
CONFIG_FATFS_LFN_HEAP=
CONFIG_FATFS_LFN_STACK=y
CONFIG_FATFS_MAX_LFN=255
CONFIG_FATFS_API_ENCODING_ANSI_OEM=y
CONFIG_FATFS_API_ENCODING_UTF_16=
CONFIG_FATFS_API_ENCODING_UTF_8=
CONFIG_FATFS_FS_LOCK=7
CONFIG_FATFS_TIMEOUT_MS=10000
CONFIG_FATFS_PER_FILE_CACHE=y
Any idea how can I reduce it. How can I used external ram for SD card.
Thanks,
Naeem
SD card mount internal RAM usage high
Re: SD card mount internal RAM usage high
Can some answer my query.
Hi snahmad75,
Currently you can only move FATFS allocations into external RAM if you tweak the allocation threshold (https://docs.espressif.com/projects/esp ... ysinternal).
We plan to add a configuration option to prefer external RAM for FATFS data structures, in IDF 3.3.
I am ok for now. I was getting low on internal ram. I reduce myESP_igrr wrote: ↑Thu Nov 29, 2018 10:31 amHi snahmad75,
CONFIG_FATFS_FS_LOCK=7 to CONFIG_FATFS_FS_LOCK=5
and change.
CONFIG_LWIP_IRAM_OPTIMIZATION=y
CONFIG_TCPIP_TASK_AFFINITY_CPU1=y
Now I can access my embedded mongoose web server with 2-3 web browser clients.
Does max_files have effect on access files simultaneous from web server . I am using mongoose webserver. Modern browser access files in parallel. I miss some files browser fail to load and it is slow.
.max_files = 3,
.max_files = 3,
My mongoose web server is reading files via http serve to read files from sd card.
Internal ram goes down very quickly. any idea which line of code is allocating internal ram. I do not want to alloc heap when reading files. stack memory should be good enough.
I (60191) W2K: Internal Heap free: 54856
D (60359) W2K: enter vfs_fat_open path=/wwwroot/index.html
D (60365) W2K: exit vfs_fat_open path=1:/wwwroot/index.html, fd=0
D (60380) W2K: vfs_fat_close fd=0
D (60421) W2K: enter vfs_fat_open path=/wwwroot/assets/bootstrap.min.css
D (60431) W2K: exit vfs_fat_open path=1:/wwwroot/assets/bootstrap.min.css, fd=0
D (60474) W2K: enter vfs_fat_open path=/wwwroot/assets/style.css
D (60481) W2K: exit vfs_fat_open path=1:/wwwroot/assets/style.css, fd=1
D (60514) W2K: enter vfs_fat_open path=/wwwroot/styles.0e4338761429b4eb16ac.css
D (60522) W2K: exit vfs_fat_open path=1:/wwwroot/styles.0e4338761429b4eb16ac.css, fd=2
D (60527) W2K: vfs_fat_close fd=2
D (60578) W2K: enter vfs_fat_open path=/wwwroot/assets/js/jquery-3.3.1.slim.min.js
D (60590) W2K: exit vfs_fat_open path=1:/wwwroot/assets/js/jquery-3.3.1.slim.min.js, fd=2
D (60646) W2K: enter vfs_fat_open path=/wwwroot/main.4229da4ed6e9ace97a97.js
D (60652) W2K: exit vfs_fat_open path=1:/wwwroot/main.4229da4ed6e9ace97a97.js, fd=3
D (60697) W2K: enter vfs_fat_open path=/wwwroot/runtime.ec2944dd8b20ec099bf3.js
D (60703) W2K: exit vfs_fat_open path=1:/wwwroot/runtime.ec2944dd8b20ec099bf3.js, fd=4
D (60736) W2K: enter vfs_fat_open path=/wwwroot/polyfills.d6c80b389a3c780d347c.js
E (60738) vfs_fat: open: no free file descriptors
D (60759) W2K: vfs_fat_close fd=4
D (61002) W2K: vfs_fat_close fd=1
D (61021) W2K: vfs_fat_close fd=0
I (61191) W2K: Internal Heap free: 39896
Users browsing this forum: Google [Bot] and 136 guests
