CMake with IDF as library and custom kconfig
permal
Postby permal » Sat Dec 08, 2018 3:56 pm
What's the correct way to make the CMake/IDF build system find kconfig-files when IDF is used as a library?
In my particular case, the project has the following structure:
<root>
|-- CMakeLists.txt
|---- main
|         |-- CMakeLists.txt
|-- externals/smooth (this is a library that links against IDF via idf_import_components and idf_link_components)
      |-- CMakeLists.txt
      |-- kconfig (this file needs to be picked up by IDF to generate CONFIG_* in sdkconfig.h
ESP_igrr
Re: CMake with IDF as library and custom kconfig
Postby ESP_igrr » Sun Dec 09, 2018 3:15 am
My understanding is that Kconfig files are only handled in components, and externals/smooth is not a component. What you might be able to do is to create one component (without any source files in it), add it to your project via EXTRA_COMPONENT_DIRS, and place Kconfig file into that component.
permal
Postby permal » Sun Dec 09, 2018 9:52 am
Thanks Iggr.
Turns out to be easy; just set IDF_EXTRA_COMPONENT_DIRS before including idf_functions.cmake
set(IDF_EXTRA_COMPONENT_DIRS "${IDF_EXTRA_COMPONENT_DIRS} ${CMAKE_CURRENT_LIST_DIR}/smooth_idf_component")
include($ENV{IDF_PATH}/tools/cmake/idf_functions.cmake)
idf_import_components(components $ENV{IDF_PATH} esp-idf)
idf_link_components(${PROJECT_NAME} "${components}")
Btw, the docs still refer to the variable as EXTRA_COMPONENT_DIRS, not IDF_...
Users browsing this forum: Majestic-12 [Bot] and 312 guests
