webserver using FATFS file system
burkulesomesh43
Postby burkulesomesh43 » Wed Dec 12, 2018 1:31 pm
Hi all,
I want to store a html file in flash and use that file for webserver.
I just want to hit whole html file not like reading it and use that variable in netconn_write(); function to hit that page.
please the the code as follows. is there any api to hit that file directly from flash?
#include "esp_wifi.h"
#include "esp_system.h"
#include "esp_event.h"
#include "esp_event_loop.h"
#include "nvs_flash.h"
#include "driver/gpio.h"
#include "freertos/portmacro.h"
#include "esp_log.h"
#include "tcpip_adapter.h"
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include "esp_vfs.h"
#include "esp_vfs_fat.h"
static EventGroupHandle_t wifi_event_group;
const int CONNECTED_BIT = BIT0;
static char* TAG = "webserver-file";
#include "lwip/err.h"
#include "string.h"
// Handle of the wear levelling library instance
static wl_handle_t s_wl_handle = WL_INVALID_HANDLE;
// Mount path for the partition
const char *base_path = "/spiflash";
const static char http_html_hdr[] =
    "HTTP/1.1 200 OK\r\nContent-type: text/html\r\n\r\n";
const static char http_index_hml[] ="<!DOCTYPE html>"
		"<html>"
		"<body>"
		"<form action=\"/action_page.php\">"
		"Select a file: <input type=\"file\" name=\"myFile\"><br><br>"
		"<input type=\"submit\">"
		"</form>"
		"</body>"
		"</html>";
#include "lwip/sys.h"
#include "lwip/netdb.h"
#include "lwip/api.h"
static esp_err_t event_handler(void *ctx, system_event_t *event)
    switch(event->event_id) {
    case SYSTEM_EVENT_STA_START:
        esp_wifi_connect();
    case SYSTEM_EVENT_STA_GOT_IP:
        xEventGroupSetBits(wifi_event_group, CONNECTED_BIT);
        printf("got ip\n");
        printf("ip: " IPSTR "\n", IP2STR(&event->event_info.got_ip.ip_info.ip));
        printf("netmask: " IPSTR "\n", IP2STR(&event->event_info.got_ip.ip_info.netmask));
        printf("gw: " IPSTR "\n", IP2STR(&event->event_info.got_ip.ip_info.gw));
        printf("\n");
        fflush(stdout);
    case SYSTEM_EVENT_STA_DISCONNECTED:
        /* This is a workaround as ESP32 WiFi libs don't currently
           auto-reassociate. */
        esp_wifi_connect();
        xEventGroupClearBits(wifi_event_group, CONNECTED_BIT);
    default:
    return ESP_OK;
static void initialise_wifi(void)
    tcpip_adapter_init();
    wifi_event_group = xEventGroupCreate();
    ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
    ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
    ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
    wifi_config_t sta_config = {
        .sta = {
            .ssid = "niruha",
            .password = "1234567890",
            .bssid_set = false
    ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_STA, &sta_config) );
static void
http_server_netconn_serve(struct netconn *conn)
  struct netbuf *inbuf;
  char *buf;
  u16_t buflen;
  err_t err;
  /* Read the data from the port, blocking if nothing yet there.
   We assume the request (the part we care about) is in one netbuf */
  err = netconn_recv(conn, &inbuf);
  if (err == ERR_OK) {
    netbuf_data(inbuf, (void**)&buf, &buflen);
    // strncpy(_mBuffer, buf, buflen);
    /* Is this an HTTP GET command? (only check the first 5 chars, since
    there are other formats for GET, and we're keeping it very simple )*/
    printf("buffer = %s \n", buf);
    if (buflen>=5 &&
        buf[0]=='G' &&
        buf[1]=='E' &&
        buf[2]=='T' &&
        buf[3]==' ' &&
        buf[4]=='/' ) {
          printf("buf[5] = %c\n", buf[5]);
      /* Send the HTML header
             * subtract 1 from the size, since we dont send the \0 in the string
             * NETCONN_NOCOPY: our data is const static, so no need to copy it
      // Open file for reading
             ESP_LOGI(TAG, "Reading file");
             FILE* f = fopen("/spiflash/hello.txt", "rb");
             if (f == NULL) {
                 ESP_LOGE(TAG, "Failed to open file for reading");
                 return;
             char line[500];
             fgets(line, sizeof(line), f);
             fclose(f);
             // strip newline
             char *pos = strchr(line, '\n');
             if (pos) {
                 *pos = '\0';
             ESP_LOGI(TAG, "Read from file: '%s'", line);
      netconn_write(conn, http_html_hdr, sizeof(http_html_hdr)-1, NETCONN_NOCOPY); // Open renamed file for reading
      netconn_write(conn, line, strlen(line)-1, NETCONN_NOCOPY);
  /* Close the connection (server closes in HTTP) */
  netconn_close(conn);
  /* Delete the buffer (netconn_recv gives us ownership,
   so we have to make sure to deallocate the buffer) */
  netbuf_delete(inbuf);
static void http_server(void *pvParameters)
  struct netconn *conn, *newconn;
  err_t err;
  conn = netconn_new(NETCONN_TCP);
  netconn_bind(conn, NULL, 80);
  netconn_listen(conn);
  do {
     err = netconn_accept(conn, &newconn);
       http_server_netconn_serve(newconn);
       netconn_delete(newconn);
   } while(err == ERR_OK);
   netconn_delete(conn);
int app_main(void)
    nvs_flash_init();
    ESP_LOGI(TAG, "Mounting FAT filesystem");
        // To mount device we need name of device partition, define base_path
        // and allow format partition in case if it is new one and was not formated before
        const esp_vfs_fat_mount_config_t mount_config = {
                .max_files = 4,
                .format_if_mount_failed = true,
                .allocation_unit_size = CONFIG_WL_SECTOR_SIZE
        esp_err_t err = esp_vfs_fat_spiflash_mount(base_path, "storage", &mount_config, &s_wl_handle);
        if (err != ESP_OK) {
            ESP_LOGE(TAG, "Failed to mount FATFS (%s)", esp_err_to_name(err));
            return;
        ESP_LOGI(TAG, "Opening file");
        FILE *f = fopen("/spiflash/hello.txt", "wb");
        if (f == NULL) {
            ESP_LOGE(TAG, "Failed to open file for writing");
            return;
        fprintf(f, "%s\n",http_index_hml);
        fclose(f);
        ESP_LOGI(TAG, "File written");
    initialise_wifi();
    xTaskCreate(&http_server, "http_server", 1024*4, NULL, 5, NULL);
    return 0;
Last edited by burkulesomesh43 on Mon Dec 17, 2018 8:21 am, edited 2 times in total.
Somesh Burkule
brp80000
Re: webserver using FATFS file system
Postby brp80000 » Wed Dec 12, 2018 5:33 pm
I am use part of code for the same (fatfs to webserver) from this GIT
https://github.com/limiter121/esp32-obd2-emulator
burkulesomesh43
Postby burkulesomesh43 » Thu Dec 13, 2018 4:49 am
It gives an error. there is no header in esp idf.
C:/esp-idf-v3.1.1/examples/somesh/webserver-file/main/main.c:26:25: fatal error: http_server.h: No such file or directory
compilation terminated.
Somesh Burkule
ESP_Anurag
Postby ESP_Anurag » Thu Dec 13, 2018 6:18 am
ESP-IDF has it's own native http server now (see esp_http_server). Check this answer, from a previous post, about serving files off a FAT formatted SD card : viewtopic.php?p=29992#p29992
burkulesomesh43
Postby burkulesomesh43 » Thu Dec 13, 2018 6:59 am
I am using esp-idf v3.1.1 which does not have esp_http_server.
Somesh Burkule
burkulesomesh43
Postby burkulesomesh43 » Thu Dec 13, 2018 7:30 am
can i use the files like used in following link.
http://zerothelement21.blogspot.com/201 ... f-sdk.html
but i dont know then where this file is stored. in EEPROM or in code.
Somesh Burkule
ESP_Anurag
Postby ESP_Anurag » Thu Dec 13, 2018 9:04 am
Yes you can. As described in the link, you simply need to put the following in your component.mk
COMPONENT_EMBED_FILES := index.html
And use the following two pointers in your code to track the start and end of the file
extern const uint8_t index_html_start[] asm("_binary_index_html_start");
extern const uint8_t index_html_end[] asm("_binary_index_html_end");
It's stored in flash, and is very simple to access using the two pointers. You just need to write a URI handler function like this:
esp_err_t index_html_get_handler(httpd_req_t *req)
    httpd_resp_send(req, (const char*)index_html_start, (index_html_end - index_html_start));
    return ESP_OK;
And inside your main function start the server and register the URI handler:
    httpd_handle_t server = NULL;
    httpd_config_t config = HTTPD_DEFAULT_CONFIG();
    httpd_uri_t index_html = {
        .uri       = "/",
        .method    = HTTP_GET,
        .handler   = index_html_get_handler,
        .user_ctx  = NULL
    httpd_start(&server, &config);
    httpd_register_uri_handler(server, &index_html);
All httpd_ APIs are available from esp_http_server.h
jcsbanks
Postby jcsbanks » Thu Dec 13, 2018 11:41 pm
W (14605) httpd_parse: parse_block: response uri/header too big
W (14605) httpd_txrx: httpd_resp_send_err: 431 Request Header Fields Too Large - Header fields are too long for server to interpret
W (14615) httpd_parse: parse_block: incomplete (1/21) with parser error = 16
W (14625) httpd_txrx: httpd_resp_send_err: 400 Bad Request - Server unable to understand request due to invalid syntax
W (14635) httpd_parse: parse_block: incomplete (0/31) with parser error = 16
When using the modifications suggested above to http_server/simple and trying an http POST, I get the above errors.
The POST is:
POST http://192.168.1.113/ HTTP/1.1
Host: 192.168.1.113
Connection: keep-alive
Content-Length: 31
Cache-Control: max-age=0
Origin: http://192.168.1.113
Upgrade-Insecure-Requests: 1
Content-Type: application/x-www-form-urlencoded
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.80 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
Referer: http://192.168.1.113/
Accept-Encoding: gzip, deflate
Accept-Language: en-GB,en-US;q=0.9,en;q=0.8
firstname=Mickey&lastname=Mouse
Increasing
#define PARSER_BLOCK_SIZE  128
in esp_httpd_priv.h makes no difference.
Trying to track down the source of the error.
jcsbanks
Postby jcsbanks » Fri Dec 14, 2018 12:18 am
CONFIG_HTTPD_MAX_REQ_HDR_LEN=1024
CONFIG_HTTPD_MAX_URI_LEN=1024
In sdkconfig (original values 512) fixes it.
The content length from Chrome for a short POST was 548 bytes.
ESP_Anurag
Postby ESP_Anurag » Mon Dec 17, 2018 6:33 am
You can have a sdkconfig.defaults in your project folder with the config value overrides, or use `make menuconfig` to override these values
Users browsing this forum: Google [Bot], mahone and 215 guests
