Faster, optimized ESP-IDF fork + PSRAM Issues
Re: Faster, optimized ESP-IDF fork + PSRAM Issues
Postby ESP_Sprite » Thu Apr 25, 2019 2:06 am
FWIW, we've been trying some workarounds and I'm pretty sure we can find a set of rules to make these problems go away, but the devs responsible (mostly me) have been doing other high-prio things as well. I'm hoping I can find time to finally finish this in the next few weeks.
markwj
Postby markwj » Thu Apr 25, 2019 2:12 am
Thanks for the update. Very helpful.
If/when you get a toolchain, please let us know. This is impacting us quite badly.
Ritesh
Contact:
Postby Ritesh » Sun Apr 28, 2019 9:58 am
Would you please describe issue into one or two lines like what will create impact while using ESP32 IDF 3.1 Release with PSRAM?
Regards,
Ritesh Prajapati
jcsbanks
Postby jcsbanks » Thu May 16, 2019 9:26 am
Is there any update on this? I'm using 4MB of PSRAM and both cores, and dare not release our product.
Ritesh
Contact:
Postby Ritesh » Fri May 17, 2019 3:14 am
Espressif SDK Team,
Would you please look few queries raised by me and few developers? So that I and they can move further with PSRAM without any issue.
Regards,
Ritesh Prajapati
jcsbanks
Postby jcsbanks » Tue May 21, 2019 7:25 pm
@ESP_Sprite Please can we have an update on this issue? I am delaying product release until 3.3 is out of beta, but also until there is some more info on this.
Postby ESP_Sprite » Wed May 22, 2019 3:19 am
Yes. I finally got back to looking into this, but unfortunately no exact timeframe when I can give you guys a toolchain to test.
Ritesh
Contact:
Postby Ritesh » Wed May 22, 2019 3:52 am
markwj wrote:
Thu Apr 25, 2019 1:45 am
We're coming into 4 months after this bug was reported, but no movement on the GitHub issue.
This is a fundamental random memory corruption fault that is causing all sorts of issues. Can we get a resolution, or at least an update as to what is going on?
which IDF right now you are using?
Regards,
Ritesh Prajapati
Postby ESP_Sprite » Wed May 22, 2019 4:56 am
How does that matter? It's a toolchain issue, not an esp-idf one.
Ritesh
Contact:
Postby Ritesh » Wed May 22, 2019 8:14 am
ok. Fine. No issues.
Regards,
Ritesh Prajapati
Users browsing this forum: Bing [Bot], ESP_Angus and 37 guests
