I'm new to ESP32
i'm trying to write a program in eclipse
i've followed the youtube link: https://www.youtube.com/watch?v=bYh2w0HzS7s&t=726s
it works good
now i wanted to add bluetooth functionality (getting the bt address) to the program
so i've included:
${IDF_PATH}/components/bt/bluedroid/api/include
${IDF_PATH}/components/bt/include
and add to the program:
#include "api/esp_bt_device.h"
and build it.
i've got an error: fatal error: api/esp_bt_device.h: No such file or directory
ive check my sdkconfig file:
CONFIG_BT_ENABLED=y
CONFIG_BLUEDROID_ENABLED=y
there are more for the config but those lines are the important once (at least this is what i understand)
inside the build folder, i've found that the
esp_bt_device.o
esp_bt_device.d
I've clean all build, and rebuild
refresh the indexer
nothing works
so what am i missing?
my OS is windows 7 64-bit
I've attached 3 images:
1. the code with the includes(complete path) and build folder
2. the Paths And Symbols that shws the includes
3. the api/include folder that shows that the esp_bt_device.h exists
Thank you
api/esp_bt_device.h: No such file or directory even it's included
- 3.png (123.4 KiB) Viewed 4123 times
- 2.png (90.59 KiB) Viewed 4123 times
- 1.png (214.6 KiB) Viewed 4123 times
Users browsing this forum: Bing [Bot], oshmykov-dev and 240 guests
