Hello everybody,
like explained on this site https://docs.espressif.com/projects/esp ... rupts.html I have added the symbol name of my assembly file to the COMPONENT_ADD_LDFLAGS line, but the linker is ignoring it. I am using the component.mk file located in .platformio/packages/framework-espidf/components/esp32/
Is there anyway to output the assembly file of my hole program to verify if my assembly file is linked while building ?
thank you
LDFLAG with unresolved symbol not working
Re: LDFLAG with unresolved symbol not working
You can use 'objdump -S build/projectname.elf' and see if the function is in the assembly output.
Hello ESP_Sprite !
Thank you for the hint ! I am using the following command to do it:
which outputs the assembly output directly into a new file called firmware.S.
To make it a bit more comfortable, I wrote a small shell script which I can execute directly in my IDE (ATOM with PlatformIO):
Thank you !
Best regards,
opcode_x64
./xtensa-esp32-elf-objdump -d -S /..../...../...../PlatformIO/Projects/<ProjectName>/.pioenvs/esp32dev/firmware.elf >> firmware.S
#!/bin/bash
rm -r firmware.S #delete the old file...
atom firmware.S #open it directly in the currently opened "atom" session.
Best regards,
opcode_x64
Users browsing this forum: No registered users and 271 guests
