esp_http_client PUT method
Ian777
Postby Ian777 » Thu Jan 17, 2019 12:21 am
Hey everyone,
I've been looking at the esp_http_client , specifically the PUT method. I plan on using a persistent session with POST and PUT. Post will be used to login and logout from a DB. The PUT method I want to use to pass a file to the Database. The file will be stored locally on a SDcard. I can't seem to see how I could configure the file handle or something along those lines when using the PUT method.
Here's the esp-idf example I'm referring to: https://github.com/espressif/esp-idf/bl ... _example.c
Line 102 - 112 shows the method in question:
   //PUT
    esp_http_client_set_url(client, "http://httpbin.org/put");
    esp_http_client_set_method(client, HTTP_METHOD_PUT);
    err = esp_http_client_perform(client);
    if (err == ESP_OK) {
        ESP_LOGI(TAG, "HTTP PUT Status = %d, content_length = %d",
                esp_http_client_get_status_code(client),
                esp_http_client_get_content_length(client));
        ESP_LOGE(TAG, "HTTP PUT request failed: %s", esp_err_to_name(err));
I know I must just be missing it, but any help will really be appreciated!
Thanks in advance!
Users browsing this forum: Baidu [Spider], Google [Bot] and 239 guests
