I have program. which open TCP port for example 60001 for listening.
then TCP client connect.then I close socket. reopen same TCP port. It fails to open TCP listen socket "failed to open listener" because there is one or more tcp client is connected.
If donot have any client connected or client close connection before TCP server close socket. It works.
open different port also works.
Every I open same port. I get different socket handle.
I am using mongoose Networking library. It is working on Windows Platform.
To close by calling mg_mgr_free and do mg_mgr_init again then mg_bind failed which open tcp port.
I also keep list of mongoose client connections. I do closeSocket for each connected as well before and after mg_mgr_free .
Kindly help. If I restart my firmware then it works as well.
My guess is either mongoose is not closing socket properly. or something wrong with LWIP config.
My LWIP config.
# LWIP
CONFIG_L2_TO_L3_COPY=
CONFIG_LWIP_IRAM_OPTIMIZATION=
CONFIG_LWIP_MAX_SOCKETS=10
CONFIG_USE_ONLY_LWIP_SELECT=
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
CONFIG_LWIP_SO_RCVBUF=y
CONFIG_LWIP_DHCP_MAX_NTP_SERVERS=1
CONFIG_LWIP_IP_FRAG=y
CONFIG_LWIP_IP_REASSEMBLY=
CONFIG_LWIP_STATS=y
CONFIG_LWIP_ETHARP_TRUST_IP_MAC=y
CONFIG_ESP_GRATUITOUS_ARP=
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_LWIP_DHCP_DOES_ARP_CHECK=y
CONFIG_LWIP_DHCP_RESTORE_LAST_IP=
# TCP
CONFIG_LWIP_MAX_ACTIVE_TCP=6
CONFIG_LWIP_MAX_LISTENING_TCP=5
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=6
CONFIG_TCP_MSS=1436
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
CONFIG_ESP_TCP_KEEP_CONNECTION_WHEN_IP_CHANGES=y
CONFIG_TCP_OVERSIZE_MSS=y
CONFIG_TCP_OVERSIZE_QUARTER_MSS=
CONFIG_TCP_OVERSIZE_DISABLE=
# ICMP
CONFIG_LWIP_MULTICAST_PING=
CONFIG_LWIP_BROADCAST_PING=
# LWIP RAW API
CONFIG_LWIP_MAX_RAW_PCBS=16
# TCP/IP Adapter
CONFIG_IP_LOST_TIMER_INTERVAL=10
CONFIG_TCPIP_LWIP=y
Thanks,
Naeem
LWIP reopen close TCP port ( urgent)
Users browsing this forum: Baidu [Spider], Remenyo and 243 guests
