git clone not getting everything
twompark
Postby twompark » Mon Feb 11, 2019 6:57 pm
Am a bit new to this..
Followed install instructions to clone the IDF:
$ git clone -b v3.1.2 --recursive https://github.com/espressif/esp-idf.git
It ran without errors, however, many directories are missing, for example when I look:
$ ls ../esp-idf/examples/protocols/
aws_iot coap_server http_request https_mbedtls mdns openssl_server README.md udp_multicast
coap_client esp_http_client http2_request https_request openssl_client pppos_client sntp
There is no http_server example or https_server. How do I get these (or everything?)
thanks
ESP_Angus
Re: git clone not getting everything
Postby ESP_Angus » Mon Feb 11, 2019 11:19 pm
Hi twompark,
These examples are not part of ESP-IDF v3.1, which is the current stable release version.
If you check out the v3.2 release branch (git checkout release/v3.2) then it has the http_server example but not https_server.
To get both the https_server and http_server you will need to check out the master branch (git checkout master).
Some explanation about the different version types and branches can be found here: https://docs.espressif.com/projects/esp ... sions.html
Users browsing this forum: No registered users and 23 guests
