SDCARD speed on writes
__vnv__
Postby __vnv__ » Tue Mar 19, 2019 10:22 pm
Hello everyone,
I am trying to download and write on sdcard using wrover kit.
Downloading file from web and saving it seems to be pretty slow, could someone please tell if I am doing something wrong or it is just limit of the platform.
I have combined two examples, SDCARD and http_client.
To download 5Mb file and save it takes ~3.20 min.
Doing it with a laptop it is instantaneous.
Also I have tried to write to SDCARD in a for loop and it also looks pretty slow.
Code is:
/* ESP HTTP Client Example
#define LOG_LOCAL_LEVEL ESP_LOG_ERROR
#include <string.h>
#include <stdlib.h>
#include "freertos/task.h"
#include "esp_log.h"
#include "esp_system.h"
#include "nvs_flash.h"
#include "app_wifi.h"
#include "esp_http_client.h"
/* SD CARD */
#include "esp_vfs_fat.h"
#include "driver/sdmmc_host.h"
#include "driver/sdspi_host.h"
#include "sdmmc_cmd.h"
/* SD CARD */
#define USE_SPI_MODE
#ifdef USE_SPI_MODE
// Pin mapping when using SPI mode.
// With this mapping, SD card can be used both in SPI and 1-line SD mode.
// Note that a pull-up on CS line is required in SD mode.
#define PIN_NUM_MISO 2
#define PIN_NUM_MOSI 15
#define PIN_NUM_CLK  14
#define PIN_NUM_CS   13
#endif //USE_SPI_MODE
//#define MAX_HTTP_RECV_BUFFER 512
#define MAX_HTTP_RECV_BUFFER 1024
static const char *TAG = "HTTP_CLIENT";
// ------------------ GLOBAL VARS -----------------------------
FILE *fp=NULL;
uint32_t filesize_count=5245254;
/* Root cert for howsmyssl.com, taken from howsmyssl_com_root_cert.pem
   The PEM file was extracted from the output of this command:
   openssl s_client -showcerts -connect www.howsmyssl.com:443 </dev/null
   The CA root cert is the last cert given in the chain of certs.
   To embed it in the app binary, the PEM file is named
   in the component.mk COMPONENT_EMBED_TXTFILES variable.
extern const char howsmyssl_com_root_cert_pem_start[] asm("_binary_howsmyssl_com_root_cert_pem_start");
extern const char howsmyssl_com_root_cert_pem_end[]   asm("_binary_howsmyssl_com_root_cert_pem_end");
esp_err_t _http_event_handler(esp_http_client_event_t *evt)
    switch(evt->event_id) {
        case HTTP_EVENT_ERROR:
            ESP_LOGE (TAG, "HTTP_EVENT_ERROR");
        case HTTP_EVENT_ON_CONNECTED:
            ESP_LOGE (TAG, "HTTP_EVENT_ON_CONNECTED");
        case HTTP_EVENT_HEADER_SENT:
            ESP_LOGE (TAG, "HTTP_EVENT_HEADER_SENT");
        case HTTP_EVENT_ON_HEADER:
            ESP_LOGE (TAG, "HTTP_EVENT_ON_HEADER, key=%s, value=%s", evt->header_key, evt->header_value);
        case HTTP_EVENT_ON_DATA:
            filesize_count -= evt->data_len;
            ESP_LOGE (TAG, "HTTP_EVENT_ON_DATA, len=%d content left=%d bytes ", evt->data_len, filesize_count);
            if (!esp_http_client_is_chunked_response(evt->client)) {
                // Write out data
                // printf("%.*s", evt->data_len, (char*)evt->data);
                if(fp == NULL){
                    fp = fopen("/sdcard/metallica.mp3","wb");
                if(fp != NULL){
                    fwrite(evt->data,1,evt->data_len,fp);
                    //ESP_LOGE (TAG, "---------- HTTP_EVENT_ON_DATA - WRITING TO SD CARD ----------");
        case HTTP_EVENT_ON_FINISH:
            ESP_LOGE (TAG, "HTTP_EVENT_ON_FINISH");
            fclose(fp);
            fp = NULL;
        case HTTP_EVENT_DISCONNECTED:
            ESP_LOGE (TAG, "HTTP_EVENT_DISCONNECTED");
    return ESP_OK;
static void http_download_chunk()
    esp_http_client_config_t config = {
        .url = "http://hcmaslov.d-real.sci-nnov.ru/public/mp3/Metallica/Metallica%20'Blitzkrieg'.mp3",
        .event_handler = _http_event_handler,
        .buffer_size = 10240 // Tried various numbers to see if it speeds up, noting happened.
    esp_err_t err = esp_http_client_perform(client);
    if (err == ESP_OK) {
        ESP_LOGI(TAG, "HTTP chunk encoding Status = %d, content_length = %d",
                esp_http_client_get_status_code(client),
                esp_http_client_get_content_length(client));
        ESP_LOGE(TAG, "Error perform http request %s", esp_err_to_name(err));
    esp_http_client_cleanup(client);
static void http_test_task(void *pvParameters)
    app_wifi_wait_connected();
    ESP_LOGI(TAG, "Connected to AP, begin http example");
    http_download_chunk();
    ESP_LOGI(TAG, "Finish http example");
    vTaskDelete(NULL);
void app_main()
    ESP_ERROR_CHECK(ret);
    app_wifi_initialise();
    /* SDCARD SETUP */
    #ifndef USE_SPI_MODE
    ESP_LOGI(TAG, "Using SDMMC peripheral");
    sdmmc_host_t host = SDMMC_HOST_DEFAULT();
    host.max_freq_khz = SDMMC_FREQ_HIGHSPEED;
    // This initializes the slot without card detect (CD) and write protect (WP) signals.
    // Modify slot_config.gpio_cd and slot_config.gpio_wp if your board has these signals.
    sdmmc_slot_config_t slot_config = SDMMC_SLOT_CONFIG_DEFAULT();
    // To use 1-line SD mode, uncomment the following line:
    // slot_config.width = 1;
    // GPIOs 15, 2, 4, 12, 13 should have external 10k pull-ups.
    // Internal pull-ups are not sufficient. However, enabling internal pull-ups
    // does make a difference some boards, so we do that here.
    gpio_set_pull_mode(15, GPIO_PULLUP_ONLY);   // CMD, needed in 4- and 1- line modes
    gpio_set_pull_mode(2, GPIO_PULLUP_ONLY);    // D0, needed in 4- and 1-line modes
    gpio_set_pull_mode(4, GPIO_PULLUP_ONLY);    // D1, needed in 4-line mode only
    gpio_set_pull_mode(12, GPIO_PULLUP_ONLY);   // D2, needed in 4-line mode only
    gpio_set_pull_mode(13, GPIO_PULLUP_ONLY);   // D3, needed in 4- and 1-line modes
#else
    ESP_LOGI(TAG, "Using SPI peripheral");
    sdmmc_host_t host = SDSPI_HOST_DEFAULT();
    sdspi_slot_config_t slot_config = SDSPI_SLOT_CONFIG_DEFAULT();
    slot_config.gpio_miso = PIN_NUM_MISO;
    slot_config.gpio_mosi = PIN_NUM_MOSI;
    slot_config.gpio_sck  = PIN_NUM_CLK;
    slot_config.gpio_cs   = PIN_NUM_CS;
    // Options for mounting the filesystem.
    // If format_if_mount_failed is set to true, SD card will be partitioned and
    // formatted in case when mounting fails.
    esp_vfs_fat_sdmmc_mount_config_t mount_config = {
        .format_if_mount_failed = false,
        .max_files = 5,
        .allocation_unit_size = 16 * 1024
    // Use settings defined above to initialize SD card and mount FAT filesystem.
    // Note: esp_vfs_fat_sdmmc_mount is an all-in-one convenience function.
    // Please check its source code and implement error recovery when developing
    // production applications.
    sdmmc_card_t* card;
    ret = esp_vfs_fat_sdmmc_mount("/sdcard", &host, &slot_config, &mount_config, &card);
    if (ret != ESP_OK) {
        if (ret == ESP_FAIL) {
            ESP_LOGE(TAG, "Failed to mount filesystem. "
                "If you want the card to be formatted, set format_if_mount_failed = true.");
            ESP_LOGE(TAG, "Failed to initialize the card (%s). "
                "Make sure SD card lines have pull-up resistors in place.", esp_err_to_name(ret));
        return;
    // Card has been initialized, print its properties
    sdmmc_card_print_info(stdout, card);
    // Use POSIX and C standard library functions to work with files.
    // First create a file.
    ESP_LOGE(TAG, "Opening file");
    FILE* f = fopen("/sdcard/hello.txt", "w");
    if (f == NULL) {
        ESP_LOGE(TAG, "Failed to open file for writing");
        return;
    // ------------- USED TO TEST SDCARD SPEED
    // char str[1024];
    // memset (str,'Y',1024);
    // int j=0;
    // //for(int i = 0 ; i < 1048576  ; i++,j++){
    // for(int i = 0 ; i < 10240  ; i++,j++){
    // //fprintf(f, "Hello %s!\n", card->cid.name);
    //     //fprintf(f, "X");
    //     fwrite(str,1,1024,f);
    //     if(j > 1024){
    //         vTaskDelay(3);
    //         j = 0;
    // fclose(f);
    // ESP_LOGE(TAG, "File written");
    //-- xTaskCreate(&http_test_task, "http_test_task", 8192, NULL, 5, NULL);
    xTaskCreate(&http_test_task, "http_test_task", 16384, NULL, 5, NULL);
Users browsing this forum: No registered users and 306 guests
