CORRUPT HEAP around esp_ble_gatts_app_register
jumjum123
Postby jumjum123 » Fri Mar 16, 2018 11:47 am
Got an CORRUPT HEAP abort and tried to drill down with lst file.
At the end this is the way where it happens:
  • invoke_abort
    abort
    split_if_necessary
    multi_heap_malloc
    get_all_caps ret = multi_heap_malloc(heap->heap, size);
    heap_caps_malloc_default r=heap_caps_malloc( size, MALLOC_CAP_DEFAULT | MALLOC_CAP_INTERNAL );
    _malloc_r return heap_caps_malloc_default( size );
    0x 4000beaf ??
    lmsg.arg = (void *)osi_malloc(arg_len);
1. In my application a BLE Server is created like this, and it works fine
{0xBBCC:{0x1358:{value:"Hello",readable:true,writable:true,description:"bbcc 1358"}},
 0xDDEE:{0x2468:{value:"Hallo",readable:true,writable:true},
                     0x3579:{value:"Egon",readable:true}}};
Get these events during creating server
  • Event:ESP_GATTS_REG_EVT gatts_if:4
    Event:ESP_GATTS_CREATE_EVT gatts_if:4
    Event:ESP_GATTS_START_EVT gatts_if:4
    Event:ESP_GATTS_ADD_CHAR_EVT gatts_if:4
    Event:ESP_GATTS_ADD_CHAR_DESCR_EVT gatts_if:4
    Event:ESP_GATTS_REG_EVT gatts_if:5
    Event:ESP_GATTS_CREATE_EVT gatts_if:5
    Event:ESP_GATTS_START_EVT gatts_if:5
    Event:ESP_GATTS_ADD_CHAR_EVT gatts_if:5
    Event:ESP_GAP_BLE_ADV_START_COMPLETE_EVT
    Event:ESP_GAP_BLE_ADV_DATA_RAW_SET_COMPLETE_EVT
2. Next this service should be removed with esp_ble_gatts_app_unregister and there I get these events:
  • Event:ESP_GATTS_UNREG_EVT gatts_if:4
    Event:ESP_GATTS_UNREG_EVT gatts_if:5
3. and then created again (with other char for example). Thats where the bug comes up
For testing, steps are called manually, means there is a lot of time between. So there should be no overlapping of (internal)free and malloc
Is step2 is not sufficient or is there any other hint, what to do ?
jumjum123
Re: CORRUPT HEAP around esp_ble_gatts_app_register
Postby jumjum123 » Sat Mar 17, 2018 3:27 pm
I've changed step 2 to
  • delete service
    on ESP_GATTS_DELETE_EVT unreg app
    on ESP_GATTS_UNREG_EVT
    - deinit and disable Bluedroid
    - deinit and disable Controller
    - init and enable Controller again
    - init and enable Bluedroid
    - register callbacks for gap, gatts and gattc
    - set local MTU
Still get the corrupt heap
kolban
Postby kolban » Sat Mar 17, 2018 4:00 pm
A corrupt heap can be a horrible thing. There are some good diagnostic aids for tracking it down documented here:
http://esp-idf.readthedocs.io/en/latest ... debug.html
If it were me, I'd slowly step through the code and intersperse heap corruption detection checks. Ideally there will be a sequence of statements where the heap is good and then some statements later, the heap has been corrupted. We can then perform sub-division and keep drilling down to spot it. Heap corruption can occur for a number of reasons, the two biggest being:
1. We allocate X bytes of storage but write X+Y of data
2. We allocate X bytes of storage, release the storage and then continue to write to the old storage location
It is always possible that ESP-IDF code is corrupting the heap but it is also possible that user code is responsible. First task is to try and determine when it is being corrupted which may provide guidance as to which of the possibilities is the culprit.
jumjum123
Postby jumjum123 » Mon Mar 19, 2018 3:30 pm
@kolban,
thanks for your comment.
It directed me to right documents and at the end :roll: , the bug was on my side.
Users browsing this forum: batzare and 42 guests
