TG0WDT_SYS_RESET after two DEEPSLEEP_RESET
Re: TG0WDT_SYS_RESET after two DEEPSLEEP_RESET
Ok,
Thanks for the reply.
I am looking for a solution to periodically log temperature and send result once a day.
How to control the deep sleep timer from deep sleep stub and move a function to ROM?
Thanks,
Thanks,
You can't move functions to ROM, it is not writable.ginodecock wrote:move a function to ROM?
Maybe you should use a ULP program to read the temp, store it in ram, then wake up when you have to transmit.
Indeed, ULP would be more suitable for this task, and overall current consumption would be lower than if you wake up from deep sleep to measure the temperature.
Take a look at the deep sleep example, it shows how to read TSENS using the ULP.
The end product would be more complex. During guarding the temperature sensor is controlled by I2C and the temperature should be displayed on a lcd display with low energy.
Here I was hoping that the deep sleep wake up stub would make it doable to do in C-code to:
-measure temperature over I2C
-log temperature in RTC slow mem
-show it on a display over I2C
-control deep sleep timer for next sensor reading
==> If time to offload data wakeup and boot.
==> If problem temperature wakeup and alert.
Doing this on the ULP processor would be quite difficult because programming is in assembler
Not that difficult because ulp has i2c master so you don't have to implement it with bit bang.
@WiFive, you're right. Programming the ulp processor is doable using the assembler macros.
I was able to do temperature logging of the cpu temperature in RTC memory.
@Espressif, a sample of I2C with the ulp processor would be appreciated.
Thanks,
Thanks,
am not espressifginodecock wrote:@WiFive, you're right. Programming the ulp processor is doable using the assembler macros.
Thanks,
but suggest you to use simple bit bang on the ulp domain available pins.
there is no driver available
hope this helps
rudi
?WiFive wrote:Not that difficult because ulp has i2c master so you don't have to implement it with bit bang.
can be that i have you missunderstand -rudi ;-) wrote:?WiFive wrote:Not that difficult because ulp has i2c master so you don't have to implement it with bit bang.
the i2c master is bit bang mode or not ?
it sound "ulp has i2c master so you don't have to implement it with bit bang" was like
ulp has I2C Master "HW" driver
rudi ;-) wrote: ulp has I2C Master "HW" driver
The ULP co-processor can use a separate I2C controller, located in the RTC domain, to communicate with
external I2C slave devices. RTC_I2C has a limited feature set, compared to I2C0/I2C1 peripherals.
Users browsing this forum: No registered users and 59 guests
