mingw32 fails out of the box
frank3141
Postby frank3141 » Thu Aug 24, 2017 9:00 pm
Downloaded the mysys2 for windows msys2-i686-20161025.exe ran the file. Builds the directories and copies the files as expected.
When I try to execute mingw32.exe it puts up a window with a message about
Error: Could not fork child process: Resource temporarily unavailable (-1).
DLL rebasing may be required; see 'rebaseall / rebase --help'.
Attempted to rebase but script fails.
At this point esp-idf is non functional and development stops
This is just another example of new stuff breaks old stuff and developer left in the cold. This all worked a month or so ago
ESP_Angus
Re: mingw32 fails out of the box
Postby ESP_Angus » Fri Aug 25, 2017 6:23 am
Hi Frank,
Sorry to hear you've come across this problem. What version of IDF are you using?
The latest msys pre-built toolchain is 20170330, you can find it in the docs here:
http://esp-idf.readthedocs.io/en/latest ... hain-setup
From memory, some of the older msys releases used a different command to start the MSYS shell. However if you can upgrade to the latest then this is probably the best way forward unless you especially need a much older IDF version.
frank3141
Postby frank3141 » Fri Aug 25, 2017 1:47 pm
Redownloaded newest idf and mysys2. now they work. Thank you
Frank
