esp_wifi_restore() bug or missing some prerequisites in the docs?
samsam
Postby samsam » Sun Sep 24, 2017 4:10 am
I've tried to implement the esp_wifi_restore() function and fail. To illustrate the problem will use a very basic example - the esp_template where I added TAG, 2 lines debug prints and 1 line for esp_wifi_restore().
static const char *TAG = "test";
esp_err_t event_handler(void *ctx, system_event_t *event)
	ESP_LOGI(TAG, ">>>event_handler: %d", event->event_id);  //ss
    return ESP_OK;
void app_main(void)
    nvs_flash_init();
    tcpip_adapter_init();
    ESP_ERROR_CHECK( esp_event_loop_init(event_handler, NULL) );
//    ESP_LOGI(TAG, ">>>restore: ");  //ss
//    ESP_ERROR_CHECK( esp_wifi_restore());
    ESP_ERROR_CHECK( esp_wifi_set_storage(WIFI_STORAGE_RAM) );
    ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_STA) );
    wifi_config_t sta_config = {
        .sta = {
            .ssid = "XXXSSID",
            .password = "xxxpw",
            .bssid_set = false
    ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_STA, &sta_config) );
    ESP_ERROR_CHECK( esp_wifi_connect() );
The first log here is with esp_wifi_restore() commented out (like the original esp_template) and everything works ok: events handler outputs codes 2,4,7
MONITOR
--- idf_monitor on COM13 115200 ---
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0010,len:4
load:0x3fff0014,len:4340
load:0x40078000,len:0
load:0x40078000,len:11312
entry 0x40078c98
I (863) heap_init: Initializing. RAM available for dynamic allocation:
I (864) heap_init: At 3FFAE2A0 len 00001D60 (7 KiB): DRAM
I (882) heap_init: At 3FFB75C8 len 00028A38 (162 KiB): DRAM
I (939) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (998) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1057) heap_init: At 4009298C len 0000D674 (53 KiB): IRAM
I (1282) wifi: wifi firmware version: b39ed32
I (1282) wifi: config NVS flash: enabled
I (1282) wifi: config nano formating: disabled
I (1288) wifi: Init dynamic tx buffer num: 32
I (1288) wifi: Init data frame dynamic rx buffer num: 32
I (1292) wifi: Init management frame dynamic rx buffer num: 32
I (1298) wifi: wifi driver task: 3ffbbfec, prio:23, stack:4096
I (1303) wifi: Init static rx buffer num: 10
I (1307) wifi: Init dynamic rx buffer num: 32
I (1311) wifi: Init rx ampdu len mblock:7
I (1315) wifi: Init lldesc rx ampdu entry mblock:4
I (1320) wifi: wifi power manager task: 0x3ffc1360 prio: 21 stack: 2560
I (1327) wifi: wifi timer task: 3ffc23dc, prio:22, stack:3584
I (1351) wifi: Init Ampdu: 1 tx baw=6 rx baw=6
I (1351) wifi: mode : sta (24:0a:c4:06:f4:98)
I (1352) test: >>>event_handler: 2
I (2076) wifi: n:6 0, o:1 0, ap:255 255, sta:6 0, prof:1
I (2077) wifi: state: init -> auth (b0)
I (2081) wifi: state: auth -> assoc (0)
I (2090) wifi: state: assoc -> run (10)
I (2091) wifi: connected with XXXSSID, channel 6
I (2094) test: >>>event_handler: 4
I (2786) test: >>>event_handler: 7
I (12091) wifi: pm start, type:0
I (12092) wifi: active cnt: 13
In the second log esp_wifi_restore() is uncommented and included in the build: the output stucks after prints code 2 from event handler
MONITOR
entry 0x40078c98
I (862) heap_init: Initializing. RAM available for dynamic allocation:
I (863) heap_init: At 3FFAE2A0 len 00001D60 (7 KiB): DRAM
I (881) heap_init: At 3FFB75C8 len 00028A38 (162 KiB): DRAM
I (997) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1283) wifi: wifi firmware version: b39ed32
I (1283) wifi: config NVS flash: enabled
I (1284) wifi: config nano formating: disabled
I (1289) wifi: Init dynamic tx buffer num: 32
I (1289) wifi: Init data frame dynamic rx buffer num: 32
I (1293) wifi: Init management frame dynamic rx buffer num: 32
I (1299) wifi: wifi driver task: 3ffbbfec, prio:23, stack:4096
I (1305) wifi: Init static rx buffer num: 10
I (1308) wifi: Init dynamic rx buffer num: 32
I (1313) wifi: Init rx ampdu len mblock:7
I (1316) wifi: Init lldesc rx ampdu entry mblock:4
I (1321) wifi: wifi power manager task: 0x3ffc1360 prio: 21 stack: 2560
I (1327) test: >>>restore:
I (1342) wifi: wifi timer task: 3ffc15d8, prio:22, stack:3584
I (1364) wifi: Init Ampdu: 1 tx baw=6 rx baw=6
I (1364) wifi: mode : sta (24:0a:c4:06:f4:98)
I (1365) test: >>>event_handler: 2
I (2089) wifi: n:6 0, o:1 0, ap:255 255, sta:6 0, prof:1
I (2090) wifi: state: init -> auth (b0)
I (3090) wifi: state: auth -> init (2)
I (3091) wifi: n:6 0, o:6 0, ap:255 255, sta:6 0, prof:1
Users browsing this forum: No registered users and 48 guests
