Certification software reboot in loop
Posted: Thu May 31, 2018 11:55 am
by j.mouton
Hi everybody,
I follow the guide "ESP32_Certification_and_Test_Guide__EN.pdf" to put the ESP32 into FCC Certification mode. After flashing the module then rebooting it, it is stuck into a reboot loop :
flash read err, 1000
ets_main.c 371
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0x00
mode:QIO, clock div:2
load:0x40080000,len:172476
1162 mmu set 00010000, pos 00010000
1162 mmu set 00020000, pos 00020000
ho 0 tail 12 room 4
load:0xffffffff,len:-177
The second block is repeated infinitely.
My hardware is an ESP32-DevKitC and I flashed the module with ESP32 DOWNLOAD TOOL V3.6.3
Anyone get an idea ?
Re: Certification software reboot in loop
Posted: Fri Jun 01, 2018 12:53 am
by ESP_Sprite
Are you sure your ESP32 gets enough juice? Sometimes anemic USB cables can lead to issues like this. When in doubt, you can use a 5V lab power supply to power the board.
Posted: Fri Jun 01, 2018 1:05 am
by ESP_Angus
Hi j.mouton,
Try flashing the image with "--flash_mode dio" (if using esptool.py), or set DIO mode (rather than QIO mode) in the Windows flasher tool.
Angus
Posted: Fri Jun 01, 2018 7:14 am
by j.mouton
I've tried but the result is the same.
It was already my configuration as you can see on the picture :
https://imgur.com/a/iLrNnyN
