Unable to add more than 1 characteristic to a service
aschweiz
Postby aschweiz » Wed Dec 21, 2016 3:29 pm
I'm adding two characteristics to a service in the ESP_GATTS_CREATE_EVT event:
gl_test.char_uuid[0].len = ESP_UUID_LEN_16;
gl_test.char_uuid[0].uuid.uuid16 = ...;
esp_ble_gatts_add_char(gl_test.service_handle, &gl_test.char_uuid[0], ESP_GATT_PERM_READ, ESP_GATT_CHAR_PROP_BIT_READ);
gl_test.char_uuid[1].len = ESP_UUID_LEN_16;
gl_test.char_uuid[1].uuid.uuid16 = ...;
esp_ble_gatts_add_char(gl_test.service_handle, &gl_test.char_uuid[1], ESP_GATT_PERM_READ, ESP_GATT_CHAR_PROP_BIT_READ);
For each of them, I get an ESP_GATTS_ADD_CHAR_EVT event. For the second characteristic, the status is 133.
Am I doing something wrong or is there a bug in the implementation?
cheers
Andreas
aschweiz
(Solved) Re: Unable to add more than 1 characteristic to a service
Postby aschweiz » Wed Jan 04, 2017 3:34 pm
Fyi, it's working fine after I've increased the number of handles in esp_ble_gatts_create_service :-)
MarkIngle
Postby MarkIngle » Tue Feb 28, 2017 1:41 am
How did you increase the number of handles for the service? I am trying to added Body Sensor to the Heart Rate Service. Heart Rate Measurement is the only Characteristic I can get to show on the client....status 133 is being generated as well
aschweiz
Postby aschweiz » Tue Feb 28, 2017 7:59 am
It was the last parameter in esp_ble_gatts_create_service:
esp_ble_gatts_create_service(gl_test.gatt_if, &gl_test.service_id, 1 + (nofCharacteristics() * 3));
But I've since switched to the new "database"-based API where you don't have the number of characteristics any more.
johnnorbury
Postby johnnorbury » Fri Apr 21, 2017 9:03 am
Any updates on this issue?
I can't see any relevant commits on the git repo...
