gdb bug
johanan
gdb bug
Postby johanan » Tue Oct 30, 2018 6:12 pm
Looks like some GDB sport bug please check. I am unable to debug with wrover development board any more, I cant figure out why.
See GDB log
~"/builds/idf/crosstool-NG/.build/src/gdb-7.10/gdb/inline-frame.c:171: internal-error: inline_frame_this_id: Assertion `!frame_id_eq (*this_id, outer_frame_id)' failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nCreate a core file of GDB? "
Thanks.
-gdb-version
=thread-group-added,id="i1"
~"GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a5) 7.10\n"
~"Copyright (C) 2015 Free Software Foundation, Inc.\n"
~"License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law. Type \"show copying\"\nand \"show warranty\" for details.\n"
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
~"This GDB was configured as \"--host=i686-host_pc-mingw32 --target=xtensa-esp32-elf\".\nType \"show configuration\" for configuration details."
This GDB was configured as "--host=i686-host_pc-mingw32 --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
~"\nFor bug reporting instructions, please see:\n"
~"<http://www.gnu.org/software/gdb/bugs/>.\n"
~"Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/>.\n"
~"For help, type \"help\".\n"
~"Type \"apropos word\" to search for commands related to \"word\"...\n"
~"Reading symbols from C:/MyWork/ESP32/LedBlink2/LedBlink2/VisualGDB/Debug/blink.elf..."
~"done.\n"
~"Type \"apropos word\" to search for commands related to \"word\".\n"
^done
-list-features
^done,features=["frozen-varobjs","pending-breakpoints","thread-info","data-read-memory-bytes","breakpoint-notifications","ada-task-info","language-option","info-gdb-mi-command","undefined-command-error-code","exec-run-start-option"]
-gdb-set disassembly-flavor intel
^error,msg="No symbol \"disassembly\" in current context."
-gdb-set print demangle off
^done
-break-insert -f main
&"Function \"main\" not defined.\n"
^done,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="<PENDING>",pending="main",times="0",original-location="main"}
Warning: could not set a breakpoint on main. 'Step into new instance' will not work.
-break-delete 1
^done
set remotetimeout 60
&"set remotetimeout 60\n"
=cmd-param-changed,param="remotetimeout",value="60"
^done
target remote :3689
&"target remote :3689\n"
~"Remote debugging using :3689\n"
=thread-group-started,id="i1",pid="42000"
=thread-created,id="1",group-id="i1"
~"0x400e0c0e in get_clk_en_mask (/builds/idf/crosstool-NG/.build/src/gdb-7.10/gdb/inline-frame.c:171: internal-error: inline_frame_this_id: Assertion `!frame_id_eq (*this_id, outer_frame_id)' failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nQuit this debugging session? "
~"(y or n) [answered Y; input not from terminal]\n"
&"\nThis is a bug, please report it."
&" For instructions, see:\n<http://www.gnu.org/software/gdb/bugs/>."
&"\n\n"
Return to “Report Bugs”
