SSL (HTTPS) server using AT firmware - accept fail
pawcuq
Postby pawcuq » Mon Dec 03, 2018 5:34 pm
I would like to set up SSL server on ESP32_DevKitc_V4 using AT commands. I've already flashed it with currently newest firmware (1.1.2.0) as in picture below:
I've connected FTDI USB->UART converter to DevKit so that I could send AT commands and connected ESP to my WiFi router. I've created SSL server as shown in AT instruction set:
AT+CIPMUX=1
AT+CIPSERVER=1,443,"SSL",1
But when I try to connect to it using Chrome I get
accept fail
TCP version
AT+CIPSERVER=1,80
works just fine. What am I doing wrong with SSL?
Thanks!
Helen L
Re: SSL (HTTPS) server using AT firmware - accept fail
Postby Helen L » Tue Dec 04, 2018 9:00 am
Does your client have the CA certificate? If not, maybe you can try AT+CIPSERVER=1,443,"SSL",0 first.
pawcuq
Postby pawcuq » Fri Dec 21, 2018 10:15 am
Tried with
and same problem occured -
accept fail
Helen L
Postby Helen L » Fri Feb 01, 2019 3:09 am
Maybe try "https://" instead of "http://" on Chrome?
Return to “Report Bugs”
