I2S-parallel example: Drive a 64x32 display
codetastic
Re: I2S-parallel example: Drive a 64x32 display
Postby codetastic » Sat Oct 13, 2018 1:27 am
embedded-creations wrote:I got I2S Parallel working in 8-bit mode so the SmartMatrix Library can refresh the panel with I2S data stored in uint8_t instead of uint16_t, cutting the RAM needed to hold the refresh buffer in half. I made the modifications inside SmartMatrix Library and not Sprite_TM's I2S Parallel example, but for anyone that needs it, hopefully this GitHub commit gets you going in the right direction (it’s not well documented in the reference manual and what I have working seems like a bit of a hack!):
https://github.com/pixelmatix/SmartMatr ... 05546c0e78
Hi EC,
I can't get this to work at all. Are you able to provide your project code?
embedded-creations
Postby embedded-creations » Thu Oct 18, 2018 12:51 pm
The link you quoted is to a commit in my project code repository, so you're close. This is the full project code:
https://github.com/pixelmatix/SmartMatrix/tree/teensylc
codetastic
Postby codetastic » Mon Oct 22, 2018 9:40 am
Thank you for that.
However, what I want to understand is how I can get this to work in a simpler example, such as the original I2S Parallel DMA example?
https://github.com/pixelmatix/esp32_I2s ... aLedMatrix
If your commit as what are the difference, it seems on face value all that needs to change is set the DMA mode to 8 bit, and then re-order the bytes before they go into the buffer, but I can't get this to work and only ever get a garbled or blank display.
Any chance you could quickly hack the DMA example ? Thank you!
                        if(k%4 == 0){
                            p->data[(i+k)+2] = v;
                        } else if(k%4 == 1) {
                        } else if(k%4 == 2) {
                            p->data[(i+k)-2] = v;
                        } else { //if(k%4 == 3)
codetastic
Postby codetastic » Tue Oct 23, 2018 7:11 am
For those that might be interested... I have turned this experimental code into an Arduino Adafruit_GFX compatible library, to allow for simple graphics and text using DMA. I have tested this with a 64x32 Matrix.
https://github.com/mrfaptastic/ESP32-RG ... el-I2S-DMA
embedded-creations
Postby embedded-creations » Tue Oct 23, 2018 11:14 am
Make sure that you make all the changes needed to put the DMA in 8 bit mode, they're all in that commit, but changes are made in several places.
djRimzi
Postby djRimzi » Tue Dec 25, 2018 3:55 pm
rudi ;-) wrote:
Sat Dec 02, 2017 2:51 am
@wobblyboots
txs again. few hours after, i figured (indexing) it out now. all data fly to the right pixel, line, row, column :mrgreen:
@jeroen
txs again
keep this in mind - this is a great example for I2S, shift, latches, and in RTOS for semaphore.( update, give and more )
i try to make few changes now for an expand ( more clients, more panels.. )
@rudi ;-) what have you changed to index it right? I've got the same problem right now. Also the Animation are not so smooth on the panel. Is it because of the code or because of my wifi? Is there a newer version of your code?
Sorry for all those Questions :)
Rimzi
Postby rudi ;-) » Sun Dec 30, 2018 11:37 pm
Look here
hope this helps
marcmerlin
Postby marcmerlin » Wed Feb 20, 2019 1:42 am
I forgot to mention that if anyone needs Adafruit::GFX API, FastLED, and/or FastLED::NeoMatrix API with more than 64x32 (I think SmartMatrix supports up to 128x128 on teensy 3.6), you can use my glue library on top of Louis' SmartMatrix:
https://github.com/marcmerlin/SmartMatrix_GFX
shanghailoz
Postby shanghailoz » Thu Mar 21, 2019 3:58 pm
@codetastic
I want to say thank you for the DMA code, it works really well for me, I've left it running for a day, no crashes.
I've made a ESP32 PCB adaptor that plugs straight into the HUB75E panels, let me know if you want one, I'll post to you.
Cheers,
L.
codetastic
Postby codetastic » Sun Mar 24, 2019 10:32 pm
Hi EC,
A silly question from me.... But in order to use I2S 8bit parallel mode successfully, one needs to use an external latch / add-on card to interface with the RGB matrix right? Like the SmartLed shield etc.?
I don't understand how only being able to output 8 GPIO's in parallel can work with the typical HUB75 that needs 13 pins.
Kind Regards.
Users browsing this forum: No registered users and 6 guests
