[Video] ESP32 - DS1307 real time clock
gregstewart90
Re: [Video] ESP32 - DS1307 real time clock
Postby gregstewart90 » Fri Apr 14, 2017 6:26 pm
Got it working! Thanks Kolban for your help. My problem was with localtime(). Before using it, you have to call time().
time_t now_after;
time ( &now_after );
char buff_after[100];
strftime (buff_after, 100, "%Y-%m-%dT%H:%M:%S.000", localtime (&now_after));
I do have one problem. Sometimes the reads are okay and other times I get an error on i2c_master_cmd_begin(). The error is ESP_ERR_TIMEOUT. It will work for a long time and then on a reboot wont work. Eventually it starts working again after several reboots. Kolban I am using your code for the DS1307. I found this https://github.com/espressif/esp-idf/issues/422, but the solution didn't help.
Thoughts?
tbnobody
Postby tbnobody » Mon Aug 14, 2017 12:32 am
I am having exactly the same problem. I am using a DS3231 (which is nearly compatible with the DS1307) but I cannot read anything using the ESP-IDF. If I use the Arduino environment (as a component in an IDF project) everything works fine.
The arduino code which I am using is from this site: http://tronixstuff.com/2014/12/01/tutor ... h-arduino/
The IDF code which I am using is from here: https://github.com/nkolban/esp32-snippe ... c/ds1307.c
I am able to write the time but reading just gives me a timeout error:
D (1108) ds3231: >> ds1307
D (1111) ds3231: >> writeValue: 1502670328
D (1115) ds3231:  - Mon Aug 14 00:25:28 2017
E (2120) ds3231: i2c_master_cmd_begin: 263
D (2120) ds3231: time: 14
ESP_ERROR_CHECK failed: esp_err_t 0x107 at 0x400e3aec
kolban
Postby kolban » Thu Aug 17, 2017 3:28 am
I've always needed a logic analyzer (about $5-$10 on ebay) to debug I2C or SPI issues. Looking at the logic train on the wire is (for me) the only way to debug these kinds of issues.
musabaybek
Postby musabaybek » Sat Oct 12, 2019 4:04 pm
The code that is provided here https://github.com/nkolban/esp32-snippe ... c/ds1307.c does not have make file, however I tried to create one and also component.mk files. But I face some errors like; "fatal error: errorhandle_func.h: No such file or directory"
I'm new to esp32 and idf based coding... Can you please help?
cndgeek
Postby cndgeek » Sun Jul 17, 2022 1:29 pm
So much confusion in all the above!!!
This should help everyone sort stuff out:
  1. /* Constructor for the RTC on the logging shield. */
  2. DFRobot_DS1307 DS1307;
  3. char daynames[]="SUN\0MON\0TUE\0WED\0THU\0FRI\0SAT\0";
  4.
  5. // Set the ESP32 time from the RTC.
  6. bool StartRTC() { // See http://www.rinkydinkelectronics.com/resource/DS1307/DS1307.pdf
  7.   if( !(DS1307.begin()) ){
  8.     Serial.println(F("Communication with DS1307 RTC device failed"));
  9.     return 1;
  10.   }
  11.   struct dsTimeStruct {
  12.     uint16_t tm_sec;         /* seconds,  range 0 to 59          */
  13.     uint16_t tm_min;         /* minutes, range 0 to 59           */
  14.     uint16_t tm_hour;        /* hours, range 0 to 23             */
  15.     uint16_t tm_wday;        /* day of the week, range 0 to 6    */
  16.     uint16_t tm_mday;        /* day of the month, range 1 to 31  */
  17.     uint16_t tm_mon;         /* month, range 1 to 12 (not 0 to 11!) */
  18.     uint16_t tm_year;        /* The number of years since 1900   */
  19.     uint16_t tm_yday;        /* day in the year, range 0 to 365  */
  20.     uint16_t tm_isdst;       /* daylight saving time             */
  21.   } dstm ={0};
  22.
  23.   DS1307.getTime((uint16_t *)&dstm); //dstm.tm_mon--; // The month on the DS1307 is 1-12.
  24.
  25.   Serial.printf("DS1307 time: %s %4d/%02d/%02d %02d:%02d:%02d UTC\r\n", // DS1307 time: SUN 2022/07/17 13:06:10 UTC
  26.   &daynames[dstm.tm_wday*4], //Weekday  &daynames[(getTimeBuff[3])*4], //Weekday  [3]
  27.             dstm.tm_year, // Year [6]
  28.             dstm.tm_mon,  // Month [5]
  29.             dstm.tm_mday, // Day [4]
  30.             dstm.tm_hour, // Hours  dstm.dsRaw[2]
  31.             dstm.tm_min,  // Mins   dstm.dsRaw[1]
  32.             dstm.tm_sec   // seconds dstm.dsRaw[0]
  33.             );
  34.
  35.
  36.   time_t seconds;
  37.   time(&seconds); // Put the time into seconds
  38.   struct tm *esptm;
  39.   esptm=gmtime(&seconds);
  40.   Serial.printf("ESP32 internal time: %s",asctime(esptm)); // ESP32 internal time: Thu Jan  1 00:00:00 1970
  41.
  42.
  43.   //DS1307 format is not same as linux ( they put the tm_wday in the middle, and don't have yday and isdst).
  44.   struct tm newdstm;  newdstm.tm_sec =dstm.tm_sec; newdstm.tm_min =dstm.tm_min; newdstm.tm_hour=dstm.tm_hour;
  45.   newdstm.tm_wday=dstm.tm_wday; newdstm.tm_mday=dstm.tm_mday; newdstm.tm_mon =dstm.tm_mon-1; newdstm.tm_year=dstm.tm_year-1900;
  46.   // Serial.printf("newdstm time: %s",asctime(&newdstm)); // newdstm time: Mon Jul 17 13:09:32 2022
  47.   struct timeval dstv = { .tv_sec = mktime(&newdstm), .tv_usec = 0}; // &dstm.tm_ds
  48.   settimeofday(&dstv, NULL);
  49.
  50.   time(&seconds); // Put the updated-above time into seconds
  51.   esptm=gmtime(&seconds); // Convert epoc-based to D/M/Y...
  52.   Serial.printf("new ESP32 internal time: %s",asctime(esptm)); // new ESP32 internal time: Sun Jul 17 13:14:29 2022
  53.
  54.   return 0;
  55. } // StartRTC
Users browsing this forum: No registered users and 81 guests
