is ESP-Mesh + softAP possible
Weigen Qiu
Postby Weigen Qiu » Wed Jul 15, 2020 5:03 pm
Hi There,
Is it possible to modify the ip_internal_network sample code, such that not only all ESp32-S2 devices can communicate with each other, but also external devices (such as cellphones) can see ESP32-S2 as softAP (just like Google Mesh)? i.e. use mesh network to turn ESP32-S2 as wifi extender/repeater?
I saw an example of use ESp32-S2 for NAT: https://github.com/jonask1337/esp-idf-nat-example. It does not use MESH unfortunately.
Is it possible to implement that? I understand there is a limit for number of connections for each softAP, but can we just make the softAP visible to external world at least?
thanks in advance.
ESP-QI
Re: is ESP-Mesh + softAP possible
Postby ESP-QI » Thu Jul 16, 2020 3:05 am
Hi Weigen,
Thanks for your question.
We will implement the function as you said to let non ESP-Mesh devices access to the ESP-Mesh networks.
Will let you know when this function is merged.
Weigen Qiu
Postby Weigen Qiu » Thu Jul 16, 2020 5:16 am
I really appreciate that. thank you.
Weigen Qiu
Postby Weigen Qiu » Wed Aug 12, 2020 4:28 pm
any progress on this?
xenpac
Postby xenpac » Mon Apr 05, 2021 5:24 pm
Also looking for this. (wifi extension via mesh)
Is that implemented in the ESP-MDF ?
jpatel
Postby jpatel » Wed May 19, 2021 9:16 am
Is there any process?
I am also looking for same kind of example ESP-Mesh (jusk like google mesh).
Any help on this appreciate.
Thank you,
Jignesh Patel
clementfumey
Postby clementfumey » Wed Jun 16, 2021 9:01 am
I'm also interested in this configuration. Does anyone manage to get something working ?
nbietz
Postby nbietz » Mon Jan 10, 2022 1:40 am
Hi, I am also looking for TCP/IP support on the ESP-MESH wifi.
Thanks!
Users browsing this forum: No registered users and 37 guests
