- #include "BLEDevice.h"
- // The remote service we wish to connect to.
- static BLEUUID serviceUUID("0000AA20");
- // The characteristic of the remote service we are interested in.
- static BLEUUID charUUID("0000AA21");
- static boolean doConnect = false;
- static boolean connected = false;
- static boolean doScan = false;
- static BLERemoteCharacteristic* pRemoteCharacteristic;
- static BLEAdvertisedDevice* myDevice;
- static void notifyCallback(
- BLERemoteCharacteristic* pBLERemoteCharacteristic,
- uint8_t* pData,
- size_t length,
- bool isNotify) {
- class MyClientCallback : public BLEClientCallbacks {
- void onConnect(BLEClient* pclient) {
- void onDisconnect(BLEClient* pclient) {
- connected = false;
- Serial.println("onDisconnect");
- bool connectToServer() {
- Serial.print("Forming a connection to ");
- Serial.println(myDevice->getAddress().toString().c_str());
- BLEClient* pClient = BLEDevice::createClient();
- Serial.println(" - Created client");
- pClient->setClientCallbacks(new MyClientCallback());
- // Connect to the remote BLE Server.
- pClient->connect(myDevice); // if you pass BLEAdvertisedDevice instead of address, it will be recognized type of peer device address (public or private)
- Serial.println(" - Connected to server");
- // Obtain a reference to the service we are after in the remote BLE server.
- BLERemoteService* pRemoteService = pClient->getService(serviceUUID);
- if (pRemoteService == nullptr) {
- Serial.print("Failed to find our service UUID: ");
- Serial.println(serviceUUID.toString().c_str());
- pClient->disconnect();
- return false;
- Serial.println(" - Found our service");
- // Obtain a reference to the characteristic in the service of the remote BLE server.
- pRemoteCharacteristic = pRemoteService->getCharacteristic(charUUID);
- if (pRemoteCharacteristic == nullptr) {
- Serial.print("Failed to find our characteristic UUID: ");
- Serial.println(charUUID.toString().c_str());
- return false;
- Serial.println(" - Found our characteristic");
- // Read the value of the characteristic.
- if(pRemoteCharacteristic->canRead()) {
- std::string value = pRemoteCharacteristic->readValue();
- Serial.print("The characteristic value was: ");
- Serial.println(value.c_str());
- if(pRemoteCharacteristic->canNotify())
- pRemoteCharacteristic->registerForNotify(notifyCallback);
- connected = true;
- * Scan for BLE servers and find the first one that advertises the service we are looking for.
- class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
- * Called for each advertising BLE server.
- void onResult(BLEAdvertisedDevice advertisedDevice) {
- Serial.print("BLE Advertised Device found: ");
- Serial.println(advertisedDevice.toString().c_str());
- // We have found a device, let us now see if it contains the service we are looking for.
- if (advertisedDevice.haveServiceUUID() && advertisedDevice.isAdvertisingService(serviceUUID)) {
- BLEDevice::getScan()->stop();
- myDevice = new BLEAdvertisedDevice(advertisedDevice);
- doConnect = true;
- doScan = true;
- } // Found our server
- } // onResult
- }; // MyAdvertisedDeviceCallbacks
- void setup() {
- Serial.begin(115200);
- Serial.println("Starting Arduino BLE Client application...");
- BLEDevice::init("");
- // Retrieve a Scanner and set the callback we want to use to be informed when we
- // have detected a new device. Specify that we want active scanning and start the
- // scan to run for 5 seconds.
- BLEScan* pBLEScan = BLEDevice::getScan();
- pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
- pBLEScan->setInterval(1349);
- pBLEScan->setWindow(449);
- pBLEScan->setActiveScan(true);
- pBLEScan->start(5, false);
- } // End of setup.
- // This is the Arduino main loop function.
- void loop() {
- // If the flag "doConnect" is true then we have scanned for and found the desired
- // BLE Server with which we wish to connect. Now we connect to it. Once we are
- // connected we set the connected flag to be true.
- if (doConnect == true) {
- if (connectToServer()) {
- Serial.println("We are now connected to the BLE Server.");
- } else {
- Serial.println("We have failed to connect to the server; there is nothin more we will do.");
- doConnect = false;
- // If we are connected to a peer BLE Server, update the characteristic each time we are reached
- // with the current time since boot.
- if (connected) {
- String newValue = "Canopus: " + String(millis()/1000);
- pRemoteCharacteristic->writeValue(newValue.c_str(), newValue.length());
- Serial.print("\r\n - Result sensor");
- Serial.printf("\r\nLength : %d\r\n", value.length());
- Serial.print(" 0x"); Serial.print((uint8_t)value[0], HEX);
- Serial.print(" 0x"); Serial.print((uint8_t)value[1], HEX);
- Serial.print(" 0x"); Serial.print((uint8_t)value[2], HEX);
- Serial.print(" 0x"); Serial.print((uint8_t)value[3], HEX);
- Serial.print(" 0x"); Serial.print((uint8_t)value[4], HEX);
- Serial.print(" 0x"); Serial.print((uint8_t)value[5], HEX);
- float temp = value[1]*100+value[2];
- if(value[1]==1)
- temp=temp*-1;
- Serial.printf("\r\nTemp: %.02f*C", temp/100);
- float humi = value[4]*100+value[5];
- Serial.printf("\r\nHumi: %.02f/%", humi/100);
- }else if(doScan){
- BLEDevice::getScan()->start(0); // this is just example to start scan after disconnect, most likely there is better way to do it in arduino
- delay(3000); // Delay a second between loops.
- } // End of loop
BLE Temperature e Humidty with ESP32
This is a code to use with Jinou Beacon sensor. Its working but has a lot to do, i need some help to work with multiple beacons. I think its needed to use this:
Users browsing this forum: No registered users and 36 guests
