is ESP-Mesh + softAP possible
Weigen Qiu
Postby Weigen Qiu » Wed Jul 15, 2020 5:03 pm
Hi There,
Is it possible to modify the ip_internal_network sample code, such that not only all ESp32-S2 devices can communicate with each other, but also external devices (such as cellphones) can see ESP32-S2 as softAP (just like Google Mesh)? i.e. use mesh network to turn ESP32-S2 as wifi extender/repeater?
I saw an example of use ESp32-S2 for NAT: https://github.com/jonask1337/esp-idf-nat-example. It does not use MESH unfortunately.
Is it possible to implement that? I understand there is a limit for number of connections for each softAP, but can we just make the softAP visible to external world at least?
thanks in advance.
ESP-QI
Re: is ESP-Mesh + softAP possible
Postby ESP-QI » Thu Jul 16, 2020 3:05 am
Hi Weigen,
Thanks for your question.
We will implement the function as you said to let non ESP-Mesh devices access to the ESP-Mesh networks.
Will let you know when this function is merged.
Weigen Qiu
Postby Weigen Qiu » Thu Jul 16, 2020 5:16 am
I really appreciate that. thank you.
Weigen Qiu
Postby Weigen Qiu » Wed Aug 12, 2020 4:28 pm
any progress on this?
