I just added example that is using USB device peripheral on S2 together with sd card (SPI). As the result we have simply sd card reader:
https://github.com/chegewara/EspTinyUSB ... les/sd_msc
With small amount of code it can be used to OTA update S2 with drag n drop.
Example requires to use changes from this PR
https://github.com/espressif/arduino-esp32/pull/4777
S2 as sd card reader
Re: S2 as sd card reader
Repository deleted?
I wanted to check the code but it’s not anymore there. Has it been replaced by another example?
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
Not deleted, just changed folders structure:
https://github.com/chegewara/EspTinyUSB ... msc/sd_msc
Users browsing this forum: No registered users and 71 guests
