S2 as sd card reader
chegewara
Postby chegewara » Fri Feb 05, 2021 12:30 pm
I just added example that is using USB device peripheral on S2 together with sd card (SPI). As the result we have simply sd card reader:
https://github.com/chegewara/EspTinyUSB ... les/sd_msc
With small amount of code it can be used to OTA update S2 with drag n drop.
Example requires to use changes from this PR
https://github.com/espressif/arduino-esp32/pull/4777
fasani
Contact:
Re: S2 as sd card reader
Postby fasani » Sun Sep 12, 2021 4:57 am
Repository deleted?
I wanted to check the code but it’s not anymore there. Has it been replaced by another example?
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
chegewara
Postby chegewara » Sun Sep 12, 2021 6:21 am
Not deleted, just changed folders structure:
https://github.com/chegewara/EspTinyUSB ... msc/sd_msc
Users browsing this forum: No registered users and 23 guests
