I have got a problem with the code of the example mqtt/tcp --- espressif /
esp-idf
"https://github.com/espressif/esp-idf/t ... /mqtt/tcp",
the message is:
E (941400) TRANS_TCP: [sock=54] select() timeout
E (941400) MQTT_CLIENT: Error transport connect
I upload the same code....what's the problem?... I know that I'm doing bad. My ESP is ESP-WROOM-32...
Could anyone help me?
Thanks a lot
Problem with "example /protocols/mqtt/tcp" - ESP-WROOM-32
Re: Problem with "example /protocols/mqtt/tcp" - ESP-WROOM-32
I solved it, I was entering the broker address wrong
how did you enter the URI?
I am having the same issue, I am trying to connect to a local mosquitto broker connected on the same wifi network. I am doing this
esp_mqtt_client_config_t mqtt_cfg = {
.uri = "mqtt://10.0.2.15:1883",
//.port = 1883
//.port = 1883
What is the error msg you recieve.
If you have any type of security you need to pass that to the broker i.e. username and password
Users browsing this forum: No registered users and 54 guests
