ambiguating new declaration of 'bool esp_vApplicationIdleHook()'
techtoys
Postby techtoys » Thu Dec 08, 2022 4:41 am
Hi
I am trying to define a sleep function with esp_vApplicationIdleHook() but whenever I put it in my sketch there is an error:
Compilation error: ambiguating new declaration of 'bool esp_vApplicationIdleHook()'.
My code is simple like:
bool esp_vApplicationIdleHook(void)
  static TickType_t lastFlashTime=0;
  if((xTaskGetTickCount()-lastFlashTime) > 1000)
    Serial.println(F("It is 1 sec elapse in the idle hook."));
    lastFlashTime = xTaskGetTickCount();
  return true;
How esp_vApplicationIdleHook(void) is used actually?
Thanks for any reply in advance.
John
Re: ambiguating new declaration of 'bool esp_vApplicationIdleHook()'
Postby ESP_Sprite » Thu Dec 08, 2022 6:46 am
Not sure why you think that has a bool return type; the docs define it as `void vApplicationIdleHook( void )`.
techtoys
Postby techtoys » Thu Dec 08, 2022 7:10 am
Right, it should be
void esp_vApplicationIdleHook(void)
instead. This function is required by tasks.c and listed as a extern in portmacro.h.
Changing it back to void esp_vApplicationIdleHook(void) in the main sketch returns the error as :
multiple definition of `esp_vApplicationIdleHook'
I think it is not possible to use esp_vApplicationIdleHook() like vApplicationIdleHook() in legacy FreeRTOS. Instead, I need to call
esp_register_freertos_idle_hook(esp_freertos_idle_cb_t new_idle_cb)
to register a new callback function and this time, the new callback function type is :
typedef bool (*esp_freertos_idle_cb_t)(void)
. It returns a boolean and it is not possible to call Serial.printf() from the new callback otherwise, the application will crash. Suppose the new callback should return as soon as possible without a long delay.
Users browsing this forum: No registered users and 64 guests
