BLE Server, problems with custom advertisement and manufacturer data
ruppie
Postby ruppie » Fri Jul 10, 2020 5:51 pm
I have prepared a Test BLE Server to rebuild a LEGO HUB, Test is for Advertising only
Examle code:
  1.
  2. *
  3.     Based on Neil Kolban example for IDF: https://github.com/nkolban/esp32-snippets/blob/master/cpp_utils/tests/BLE%20Tests/SampleServer.cpp
  4.     Ported to Arduino ESP32 by Evandro Copercini
  5.     updates by chegewara
  6. */
  7. #include <Arduino.h>
  8.
  9. #include <BLEDevice.h>
  10. #include <BLEUtils.h>
  11. #include <BLEServer.h>
  12.
  13. // See the following for generating UUIDs:
  14. // https://www.uuidgenerator.net/
  15.
  16. #define SERVICE_UUID        "00001623-1212-EFDE-1623-785FEABCD123"
  17. #define CHARACTERISTIC_UUID "00001624-1212-EFDE-1623-785FEABCD123"
  18. BLEAdvertisementData oAdvertisementData = BLEAdvertisementData();
  19. //BLEAdvertisementData oScanResponseData = BLEAdvertisementData();
  20.
  21. const char advLEGO[] = {0x02,0x01,0x06,0x11,0x07,0x23,0xD1,0xBC,0xEA,0x5F,0x78,0x23,0x16,0xDE,0xEF,
  22.                           0x12,0x12,0x23,0x16,0x00,0x00,0x09,0xFF,0x97,0x03,0x00,0x80,0x06,0x00,0x61,0x00};
  23.
  24.  char  ManufacturerData[8] = {0x97,0x03,0x00,0x80,0x06,0x00,0x61,0x00};
  25.
  26.
  27.
  28. void setup() {
  29.
  30.
  31.   Serial.begin(115200);
  32.   Serial.println("Starting BLE work!");
  33.
  34.   BLEDevice::init("Long name works now");
  35.   BLEServer *pServer = BLEDevice::createServer();
  36.   BLEService *pService = pServer->createService(SERVICE_UUID);
  37.   BLECharacteristic *pCharacteristic = pService->createCharacteristic(
  38.                                          CHARACTERISTIC_UUID,
  39.                                          BLECharacteristic::PROPERTY_READ |
  40.                                          BLECharacteristic::PROPERTY_WRITE
  41.                                        );
  42.
  43.   pCharacteristic->setValue("Hello World says Neil");
  44.   pService->start();
  45.   // BLEAdvertising *pAdvertising = pServer->getAdvertising();  // this still is working for backward compatibility
  46.   BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
  47.   pAdvertising->addServiceUUID(SERVICE_UUID);
  48.
  49.    pAdvertising->setScanResponse(true);
  50.
  51.
  52. oAdvertisementData.setShortName("Lego Hub");
  53. oAdvertisementData.setManufacturerData(ManufacturerData);
  54. pAdvertising->setAdvertisementData(oAdvertisementData);
  55.
  56.   pAdvertising->setMinPreferred(0x06);  // functions that help with iPhone connections issue
  57.   pAdvertising->setMinPreferred(0x12);
  58.
  59.   BLEDevice::startAdvertising();
  60.   Serial.println("Characteristic defined! Now you can read it in your phone!");
  61. }
  62.
  63. void loop() {
  64.   // put your main code here, to run repeatedly:
  65.   delay(2000);
  66. }
Goal ist that scan and connect result from BLE Client is as follows like with original LEGO HUB:
Scanning ...<CR><LF>
[ADV 596] Packet received from 90:84:2B:4A:3A:0C<LF>
PAYLOAD 31 bytes<LF>
02-01-06-11-07-23-D1-BC-EA-5F-78-23-16-DE-EF-12-12-23-16-00-00-09-FF-97-03-00-80-06-00-41-00<CR><LF>
RSSI -29 dBm<LF>
ADV TYPE Connectable undirected<CR><LF>
128-Bit UUID #Ѽê_x#<SYN>Þï<DC2><DC2>#<SYN>00001623-1212-EFDE-1623-785FEABCD123<CR><LF>
LEGO BLE SERVICE UUID Found!<LF>
MAN SPEC DATA 97-03-00-80-06-00-41-00<CR><LF>
<CR><LF>
Connected<CR><LF>
Discovering LEGO HUB Service ... Found LEGO HUB Service <CR><LF>
Discovering characteristic ... Found LEGO Data Characteristic<CR><LF>
The result of my code from Above is like :
[ADV 655] Packet received from BC:DD:C2:CB:69:FA<LF>
PAYLOAD 14 bytes<LF>
09-08-4C-65-67-6F-20-48-75-62-03-FF-97-03<CR><LF>
RSSI -31 dBm<LF>
SHORT NAME Lego Hub<LF>
MAN SPEC DATA 97-03<CR><LF>
<CR><LF>
Connected<CR><LF>
Question is Why ?
Thanks in advance
MArc
ruppie
Re: BLE Server, problems with custom advertisement and manufacturer data
Postby ruppie » Fri Jul 10, 2020 6:05 pm
An addition:
My Advertisment data is like:
When i change code like:
oAdvertisementData.addData(advLEGO);
i got another strange result :
[ADV 1244] Packet received from BC:DD:C2:CB:69:FA<LF>
PAYLOAD 29 bytes<LF>
09-08-4C-65-67-6F-20-48-75-62-02-01-06-11-07-23-D1-BC-EA-5F-78-23-16-DE-EF-12-12-23-16<CR><LF>
RSSI -33 dBm<LF>
LEGO BLE SERVICE UUID Found!<LF><CR>
<LF>
Connected<CR><LF>
Question:
Where is the mistake not getting target result like;
Bluefruit52 Central LEGO Scan Example<CR><LF>
------------------------------------<LF><CR>
<LF>
[ADV 473] Packet received from 90:84:2B:4A:3A:0C<LF>
RSSI -28 dBm<LF>
<CR><LF>
Connected<CR><LF>
Marc
chegewara
Postby chegewara » Mon Jul 13, 2020 3:24 am
Here is error:
char string is 0x0 terminated.
std::string is not.
Here is simple test code:
#include <string>
std::string test(ManufacturerData, 8);
void setup() {
delay(100);
Serial.print("char length: ");
Serial.println(strlen(ManufacturerData));
Serial.print("std::string length: ");
Serial.println(test.length());
void loop() {
Output:
char length: 2
std::string length: 8
Users browsing this forum: No registered users and 135 guests
