How to use the built in 1V1 reference?
Emygma
Postby Emygma » Thu Apr 18, 2019 12:40 pm
I would like to take a voltage reading with one of the ADC pins via analogRead.
By default ESP32 uses whatever its current + rail voltage is as a reference,if I am not mistaken.
However, I need to use the built in 1V1 reference instead.
On arduino, this is very easy, I simply do this:
analogReference(INTERNAL);
And thats it. All analogReads now use the built in 1V1 as reference.
This code however, will not compile on the ESP32. So how do I set the ADC on the esp32 to use the built in 1V1 reference instead?
thank you
Re: How to use the built in 1V1 reference?
Postby ESP_Sprite » Fri Apr 19, 2019 2:41 am
You indeed are mistaken; it's the other way around. The ESP32 always uses the 1.1V reference, but you can switch in some attenuators to enlarge the available range.
Users browsing this forum: ESP_Alvin, jay_ar and 9 guests
