ESP32 with OV2640 Camera
Dzandaa
Postby Dzandaa » Tue May 28, 2019 5:25 pm
I have a TTGO T-Camera ESP32 WROVER with PSRAM and Camera Module OV2640
I use Arduino IDE with ESP32 Core Installation version: 1.02
The Camera Brightness, Contrast, Saturation, slider on the "CameraWebServer" doesn't not react correctly, also in a program, the last action deletes other actions, for example changing the saturation after the brightness reset the brightness
  1. //  Value and Type are int
  2.   sensor_t * s = esp_camera_sensor_get();
  3.     switch(Type)
  4.     {
  5.       case CBrightness:
  6.         s->set_brightness(s, Value);
  7.       break;
  8.       case CSaturation:
  9.         s->set_saturation(s, Value);
  10.       break;
  11.       case CContrast:
  12.         s->set_contrast(s, Value);
  13.       break;
  14.     }
  15.
I checked the camera code in comparison with the Datasheet of the OV2640 and at first sight, it seems correct.
Any idea?
Thank you.
