A fatal error occurred: Timed out waiting for packet header
Posted: Thu Jun 06, 2019 8:01 pm
by linhart
I have a question you have not encountered with the error what I further describe. ESP chips are from another delivery it's seen on the chip description. One type of ESP-WROOM-32 I ran 3 pcs without a problem. And the new type of ESP32-WROOM-32 there error appears I can't upload the program to flash memory. The same is the FCC ID on both chips.
Error in Arduino IDE:
Arduino: 1.8.9 (Windows 10), Vývojová deska: "DOIT ESP32 DEVKIT V1, 80MHz, 921600, None"
Projekt zabírá 665686 bytů (50%) úložného místa pro program. Maximum je 1310720 bytů.
Globální proměnné zabírají 39080 bytů (11%) dynamické paměti, 288600 bytů zůstává pro lokální proměnné. Maximum je 327680 bytů.
esptool.py v2.6
Serial port COM4
Connecting.......
Chip is ESP32D0WDQ6 (revision 1)
MAC: 3c:71:bf:10:5d:dc
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Warning: Could not auto-detect Flash size (FlashID=0x0, SizeID=0x0), defaulting to 4MB
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 5461.4 kbit/s)...
Error in flash_download_tools_v3.6.5
main.py:96: wxPyDeprecationWarning: Using deprecated class PySimpleApp.
('self.chip: ', 'ESP32')
RF option applied...
CONNECT BAUD: 115200
..Uploading stub...
Running stub...
Stub running...
Exception in thread Thread-1:
File "threading.py", line 801, in __bootstrap_inner
File "download_panel_info.py", line 790, in run
File "espDownloader.py", line 390, in flash_erase_test
File "espDownloader.py", line 567, in flash_erase_func
File "espDownloader.py", line 499, in esp_flash_erase_and_clr_protect
File "site-packages\esptool.py", line 64, in inner
File "site-packages\esptool.py", line 552, in erase_flash
File "site-packages\esptool.py", line 274, in check_command
File "site-packages\esptool.py", line 255, in command
File "site-packages\esptool.py", line 221, in read
File "site-packages\esptool.py", line 1575, in slip_reader
FatalError: Timed out waiting for packet content
thank you for the info
Jaroslav Linhart
