Preferences with FTP Client ESP32_FTPClient.h fails
Pcborges
Postby Pcborges » Sat Oct 12, 2019 1:27 pm
I need to initialize FTP connection with credentials stored on Preferences.
If I hard code like:
//ESP32_FTPClient ftp("host.ftpserver.com", "ftpuser", "ftppass"); //WORKS OK
preferences.begin("AppParms", true);
String myserver = preferences.getString("ftpServer","");
String myuser = preferences.getString("ftpUser","");
String mypass = preferences.getString("ftpPass","");
preferences.end();
char* ftp_server[32];
char* ftp_user[32];
char* ftp_pass[16];
strncpy(myserver.c_str(), ftp_server, 32); <-----
strncpy(myuser.c_str(), ftp_user, 32);
strncpy(mypass.c_str(), ftp_pass, 16);
I am getting invalid conversion from 'const char*' to 'char*' [-fpermissive]
Char is required to initialize:
ESP32_FTPClient ftp(ftp_server, ftp_user, ftp_pass);
That refuses to accept:
ESP32_FTPClient ftp(myserver.c_str(), myuser.c_str(), mypass.c_str());
My system=ESP32 and lib in use:
// FTP Client Lib
include "ESP32_FTPClient.h"
  char* ftp_user[32];
  char* ftp_pass[16];
  myserver.toCharArray(ftp_server, sizeof(ftp_server));
  myuser.toCharArray(ftp_user, sizeof(ftp_user));
  mypass.toCharArray(ftp_pass, sizeof(ftp_pass));
Also fails with:
no matching function for call to 'String::toCharArray(char* [32], unsigned int)'
Problem solved!
  char ftp_server[32];
  char ftp_user[32];
  char ftp_pass[16];
  //FTP parameters
  strncpy(ftp_server,preferences.getString("ftpServer").c_str(),  sizeof(ftp_server));
  strncpy(ftp_user,preferences.getString("ftpUser").c_str(),      sizeof(ftp_user));
  strncpy(ftp_pass,preferences.getString("ftpPass").c_str(),      sizeof(ftp_pass));
  preferences.end();
chegewara
Re: Preferences with FTP Client ESP32_FTPClient.h fails
Postby chegewara » Sat Oct 12, 2019 5:26 pm
1st issue is that you are instantiating array of 32/16 pointers to char:
char* ftp_user[32];
char* ftp_pass[16];
but most likely you want array of 32/16 char:
char ftp_user[32];
char ftp_pass[16];
2nd issue:
if you have error like this:
you can always cast to:
 (char*)variable
Users browsing this forum: No registered users and 49 guests
