I'm using ESP IDF v3.2 and I have initialization code like this:
- void setup() {
- setup several pins
- int serialBaud = 115200;
- Serial.begin(serialBaud);
- ... initialize a bunch of HW and read some config from the flash, including
- a variable named newBaud ...
- // change serial baudrate, if required:
- if (newBaud >= 1200 && newBaud <= 1500000 && newBaud != serialBaud) {
- Serial.printf("Custom serial baud set, changing baud-rate to %d\n", newBaud);
- Serial.flush();
- delay(2);
- Serial.end();
- serialBaud = newBaud;
- // I2C init:
- Wire.begin();
Now, I'm encountering a hang similar to issue 2015, basically the CPU locks up just after the "Custom serial baud set..." message.
We had this sort of hang during development, but I was under the impression that adding the flush and the delay(2) fixed it. And when testing it didn't show up either. Curiously enough, the hang doesn't happen if the ESP is executing the factory app, only if it's running off ota_0 or ota_1.
I was able to reproduce the issue and it happens every time locally.
The problem is that I applied an OTA update to a device that is 2000 km away...
It seems that the hang is dependent on some kind of timing, which explains the factory vs ota_0/ota_1 behaviour.
My question is:
Is there a way to instruct people in the field to do something that can modify the ESP's behaviour?
Like:
- any possibility to force the ESP boot into the factory app (I searched and it seems I need to have a special bootloader for that)?
- a way to alter the timings, or forbid the Serial printout?
If I'm able to get the device boot just once, I'll update it with the code that apparently fixes issue 2015:
- void setup() {
- Serial.flush();
- delay(2);
- Serial.updateBaudRate(serialBaud);
I had the idea of grounding GPIO15 during boot, as the docs say:
However it doesn't change a thing on my devices for some reason."If driven Low, silences boot messages printed by the ROM bootloader. Has an internal pull-up, so unconnected = High = normal output."
The only other possibility otherwise would be to send out another device with the issue fixed, but it would be a huge embarrassment from the business side. We may come off as unreliable and lose this client...
