Having installed everything as per the instructions.
Ran make menuconfig to switch to Arduino style.
Modifying a current example to run in Arduino style I am getting the error that
undefined reference to `setup()'
undefined reference to `loop()'
I have files with setup and loop in them as per the instructions in the main directory - have moved them all over, renamed them, reran clean and make and switched back and forward to ESPIDF style.
What I am doing wrong ?
Any ideas
Using as a component - problems
Re: Using as a component - problems
Also if I compile one of the esp-idf examples its fine, adding components and the arduino code it still compiles in both arduino mode and normal mode.
Its only when you remove the app_main and replace with setup and loop it just can not find it.....
Apologies for people who probably understand all this better than me, coming from a GUI background from the ESP8266 - none of this was necessary !
Solution is if your running app_main then the file needs to be a .c file
If you want to switch to Arduino you have to change the file to a .cpp file.
And then you need to go into build and delete the project directory ( usually main ) and then recompile - as it kept referencing earlier builds this was throwing a spanner in the works and I couldnt work out what was the error.
Hope this helps someone
Hi, sorry for disturbing you, I have component problems with esp32 IDF.
I have and arduino '.ino' code for esp32, that publishing MQTT, but I don't have arduino ble scan code.
And there is IDF code, that scanning for bluetooth devices, but I don't have properly working MQTT code.
So I tought I could 'add' these arduino libraries to my IDF code, and that would work, but it's not, it says:
Could I use arduino libraries in IDF, or this is a bad idea, if I can, how?
I tried many things but nothing worked, and now I don't know, where can I ask for help.
Thanks for your help.
PubSubClient.h: No such file or directory
Users browsing this forum: No registered users and 80 guests
