ENC28J60 and UIPEthernet only connects once?
krypttr
Postby krypttr » Sun May 09, 2021 11:56 am
Hello!
I trying to connect ESP32 to LAN over ethernet using ENC28J60 with UIPEthernet library. I can get ip from DHCP just fine, and the first ever connection works ok. However the next connection doesn't work and simply hangs. What might be the problem?
#include <UIPEthernet.h>
EthernetClient ethClient;
int maxtry = 0;
uint8_t mac[6] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
void BeginEth(){
    Ethernet.init(5);
    if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // Check for Ethernet hardware present
    if (Ethernet.hardwareStatus() == EthernetNoHardware) {
      Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
      while (true) {
        delay(1); // do nothing, no point running without Ethernet hardware
    if (Ethernet.linkStatus() == LinkOFF) {
      Serial.println("Ethernet cable is not connected.");
    // try to configure using IP address instead of DHCP:
    //Ethernet.begin(mac, ip, myDns);
  } else {
    Serial.print("DHCP assigned IP ");
    Serial.println(Ethernet.localIP());
void Test(){
  String url = "someurl";
  String endpoint = "someendpoint";
  String json_body = "AAA";
  while (!ethClient.connected() && maxtry < 3) {
        if (ethClient.connect(url.c_str(), 80)) {
            ethClient.print(F("POST "));
            ethClient.print(endpoint);
            ethClient.println(F(" HTTP/1.1"));
            ethClient.print(F("HOST: "));
            ethClient.println(url);
            ethClient.println(F("Content-Type: application/json"));
            ethClient.print(F("Content-Length: "));
            ethClient.println(json_body.length());
            ethClient.println();
            ethClient.print(json_body);
        } else {
            Serial.println("No connect");
            maxtry++;
            delay(1000);
    if (!ethClient.connected()) {
        Serial.println("Not connected");
        ethClient.stop();
        return;
    unsigned long timeout = millis();
    while (ethClient.available() == 0) {
        if (millis() - timeout > 5000) {
        ethClient.stop();
        delay(1000);
        Serial.println("Timeout");
    while(ethClient.available())
        Serial.print(ethClient.readStringUntil('\n'));
    Serial.println();
    ethClient.stop();
void setup(){
  Serial.begin(115200);
  BeginEth();
  delay(2000);
void loop(){
    Serial.println("Sending request");
    Test();
Users browsing this forum: Bing [Bot] and 152 guests
