I don't know if it is a bug, however I have this situation on ESP32-WROOM-32D.
In the setup function I start 2 separated tasks. One task manages the connection to WiFi network with the "Wifi.h" library, after the Wifi connection completed the task stay IDLE with a infinite loop of delays.
The other task manages the I2C sensor DHT22; it essentially init the sensor and query it in a infinite loop and print the temperatures in the Serial terminal. The libraries used are "#Adafruit_Sensor.h, DHT.h, DHT_U.h".
The problem in this configuration is I get a sensor reading failure after some random number of successful readings (meanly 8-10).
This problem doesn't occur if I perform the same Wifi connection and sensor reading in the same task. I also tried to bind the two tasks on different cores, but I have the same problem.
Anyone may help me to figure out what can be wrong?
Regards
Issue running in two different tasks Wifi and I2C device
Re: Issue running in two different tasks Wifi and I2C device
without posting your code, probably not.Anyone may help me to figure out what can be wrong?
Sure:
[/code]
- #include <Arduino.h>
- #include <WiFi.h>
- #include <Adafruit_Sensor.h>
- #include <DHT.h>
- #include <DHT_U.h>
- // DHT sensor configuration
- #define DHTPIN 16 // Digital pin connected to the DHT sensor
- #define DHTTYPE DHT22 // DHT 22 (AM2302)
- #define PRJ_DEFAULT_STACK_SIZE 8192
- // wifi credentials
- const char* ssid = "xxxxxxxxxxx";
- const char* password = "yyyyyyyyyyyyyyyy";
- void initWiFi() {
- WiFi.mode(WIFI_STA);
- WiFi.begin(ssid, password);
- Serial.print("Connecting to WiFi ..");
- while (WiFi.status() != WL_CONNECTED) {
- Serial.print('.');
- delay(1000);
- Serial.println(WiFi.localIP());
- void TaskInternetManager ( void * pvParameters ){
- Serial.print("Task TaskInternetManager running on core ");
- Serial.println(xPortGetCoreID());
- initWiFi();
- for(;;){
- delay(10000);
- DHT_Unified dht(DHTPIN, DHTTYPE);
- uint32_t delayMS;
- void initSensorsManager() {
- dht.begin();
- // Print temperature sensor details.
- sensor_t sensor;
- dht.temperature().getSensor(&sensor);
- Serial.println(F("------------------------------------"));
- Serial.println(F("Temperature Sensor"));
- Serial.print (F("Sensor Type: ")); Serial.println(sensor.name);
- Serial.print (F("Driver Ver: ")); Serial.println(sensor.version);
- Serial.print (F("Unique ID: ")); Serial.println(sensor.sensor_id);
- Serial.print (F("Max Value: ")); Serial.print(sensor.max_value); Serial.println(F("°C"));
- Serial.print (F("Min Value: ")); Serial.print(sensor.min_value); Serial.println(F("°C"));
- Serial.print (F("Resolution: ")); Serial.print(sensor.resolution); Serial.println(F("°C"));
- // Print humidity sensor details.
- dht.humidity().getSensor(&sensor);
- Serial.println(F("Humidity Sensor"));
- Serial.print (F("Max Value: ")); Serial.print(sensor.max_value); Serial.println(F("%"));
- Serial.print (F("Min Value: ")); Serial.print(sensor.min_value); Serial.println(F("%"));
- Serial.print (F("Resolution: ")); Serial.print(sensor.resolution); Serial.println(F("%"));
- // Set delay between sensor readings based on sensor details.
- delayMS = sensor.min_delay / 1000;
- void sensorLoop() {
- // Delay between measurements.
- delay(delayMS);
- // Get temperature event and print its value.
- sensors_event_t event;
- dht.temperature().getEvent(&event);
- if (isnan(event.temperature)) {
- Serial.println(F("Error reading temperature!"));
- else {
- Serial.print(F("Temperature: "));
- Serial.print(event.temperature);
- Serial.println(F("°C"));
- // Get humidity event and print its value.
- dht.humidity().getEvent(&event);
- if (isnan(event.relative_humidity)) {
- Serial.println(F("Error reading humidity!"));
- else {
- Serial.print(F("Humidity: "));
- Serial.print(event.relative_humidity);
- Serial.println(F("%"));
- void TaskSensorsManager ( void * pvParameters ){
- Serial.print("Task TaskSensorsManager running on core ");
- initSensorsManager();
- for(;;){
- sensorLoop();
- TaskHandle_t TaskInternetManagerHandle;
- TaskHandle_t TaskSensorsManagerHandle;
- void setup() {
- Serial.begin(115200);
- // Initialize device.
- Serial.println(F("HELLO WORLD"));
- xTaskCreatePinnedToCore( TaskInternetManager, "TaskInternetManager", PRJ_DEFAULT_STACK_SIZE, NULL, 1, &TaskInternetManagerHandle, 0); /* pin task to core 0 */
- xTaskCreatePinnedToCore( TaskSensorsManager, "TaskSensorsManager", PRJ_DEFAULT_STACK_SIZE, NULL, 5, &TaskSensorsManagerHandle, 0);
- vTaskDelete(NULL);
- void loop() {
Just posting here to say that I don't see any obvious interference between the two... perhaps it's a problem in the dht driver not bein built for another task intercepting it? Possibly you could try running that task on a different core?
Users browsing this forum: No registered users and 133 guests
