AutoConnect library doesn't allow to perform any other operation
spike32
Postby spike32 » Fri Oct 22, 2021 10:37 am
Hello everyone! I need to build an application in which my ESP32 uses the AutoConnect library (https://github.com/Hieromon/AutoConnect) for creating a captive portal and meanwhile performing other operations. The thing is that when I start the captive portal it doesn't perform any other operation. Here's reported some code.
#include <WiFi.h>
#include <WebServer.h>
#include <AutoConnect.h>
WebServer Server;
AutoConnect      Portal(Server);
void rootPage() {
  char content[] = "Hello, world";
  Server.send(200, "text/plain", content);
void setup() {
  delay(1000);
  Serial.begin(115200);
  Serial.println();
  Server.on("/", rootPage);
  if (Portal.begin()) {
    Serial.println("WiFi connected: " + WiFi.localIP().toString());
  Serial.println("Print after Portal.begin()");
void loop() {
    Portal.handleClient();
    Serial.println("Perform an operation...");
    delay(2000);
For instance here, in the loop() method I can't see any message printed onto my serial monitor, as well as the print after Portal.begin() is being called seems to not be executed. How can I perform more actions while the captive portal is being initialized and started?
edmoreyra
Re: AutoConnect library doesn't allow to perform any other operation
Postby edmoreyra » Wed Aug 24, 2022 10:47 pm
pre-include
WiFiManager wm;
wm.setConfigPortalBlocking(false);
wm.setConfigPortalTimeout(180); //
bool res;
res = wm.autoConnect("AutoConnectAP"); // anonymous ap
Users browsing this forum: No registered users and 70 guests
