Preference fetchString not working..... user error?
chrisvandiemen
Postby chrisvandiemen » Wed Jul 12, 2017 10:49 am
I've got some issues with the Preferences library for Arduino.
The following snippet is responsible for storing a variable to EEPROM:
int DeviceSettings::storeString(const char* key, const char* value){
  preferences.begin(name_space, false);
  Serial.println(preferences.putString(key, value), DEC);
  preferences.end();
This outputs '16', which is correct given the input I give it.
When i try to fetch the before stored variable using this code:
void DeviceSettings::fetchString(const char* key, char* value){
  Serial.println(preferences.getString(key, value, 200), DEC);
  Serial.println(value);
  preferences.end();
This outputs '0' and ''
I can't seem to understand what's happening. Both methods receive the same key:
 settings.storeString(SETTINGS_APP_NAME,"Chris van Diemen");
  char * s;
  settings.fetchString(SETTINGS_APP_NAME, s);
Is this user error of is there something else going on?
tele_player
Re: Preference fetchString not working..... user error?
Postby tele_player » Thu Jul 13, 2017 2:46 pm
At the very least, your final snippet doesn't allocate any space for
char * s;
So, s is a pointer which doesn't point to any storage.
martinayotte
Postby martinayotte » Thu Jul 13, 2017 3:33 pm
You should not using "char *s;" to define your variable, since it is an unallocated pointer, but use "char s[200];" instead ... :ugeek:
Users browsing this forum: Bing [Bot], Google [Bot] and 64 guests
