What is the meaning of startup text on ESP32
jack.fury413
Postby jack.fury413 » Mon Jul 17, 2017 4:59 pm
Hi guys, I'm wondering what the startup text means ? For example:
configsip: 0, SPIWP:0x00
mode:DIO, clock div:1
load:0x3fff0008,len:8
load:0x3fff0010,len:160
load:0x40078000,len:10632
load:0x40080000,len:252
entry 0x40080034
WiFive
Re: What is the meaning of startup text on ESP32
Postby WiFive » Mon Jul 17, 2017 10:31 pm
Reset reason code, boot mode (strapping pins)
Read spi config from efuse and flash image header
Copy 2nd stage bootloader to ram and run it
jack.fury413
Postby jack.fury413 » Tue Jul 18, 2017 1:37 am
Thanks but what is this line meaning ?
mode:DIO clock:div 1
And is there any document about this.
WiFive
Postby WiFive » Tue Jul 18, 2017 8:00 am
I think it means the SPI flash is set to DIO mode and clocked at 80mhz. This is only until the second stage bootloader takes over.
No docs about ROM bootloader really. What are you trying to figure out?
jack.fury413
Postby jack.fury413 » Tue Jul 18, 2017 1:49 pm
Thanks, seems like you get the point.
I'm trying to get the information about hardware configuration: system clock, operating mode (power saving) and reset reason (catching watchdog if any).
So if there is any place or somehow that I can get to know them, please show me.
kolban
Postby kolban » Mon Jul 24, 2017 3:51 am
Howdy,
There is a good load of information found here:
http://esp-idf.readthedocs.io/en/latest/
and also the Technical Reference Manual contains lot of good information at the lowest possible levels ... see:
http://espressif.com/sites/default/file ... ual_en.pdf
pranav
Postby pranav » Tue Jul 25, 2017 8:41 am
What Kolban has suggested is the best resource for all available APIs. However if it is the reset reasons that you need, there is an example code written for arduino-esp32 linked here.
Hope it helps you :)
jack.fury413
Postby jack.fury413 » Fri Jul 28, 2017 3:44 pm
Sorry that I was out for a while.
Thanks guys, I'm gonna check out the link, now I'm busy with the SD card issue but I think I'm gonna open another thread for it.
Users browsing this forum: Basalt, Google [Bot] and 116 guests
