I2C Slave Library Not Working
matt-s-SNAP
Postby matt-s-SNAP » Thu Jan 13, 2022 8:30 pm
I'm trying to set up an Olimex-POE module to work as an I2C slave. The docs provide an example of an I2C slave programme (https://docs.espressif.com/projects/ard ... eslave-ino). However, when I try to compile it it gives me the error:
'class TwoWire' has no member named 'slaveWrite'
If I comment that line out, it also gives me the compilation error
sketch/Olimex_Module.ino.cpp.o:(.literal._Z5setupv+0x1c): undefined reference to `TwoWire::onReceive(void (*)(int))'
sketch/Olimex_Module.ino.cpp.o:(.literal._Z5setupv+0x20): undefined reference to `TwoWire::onRequest(void (*)())'
sketch/Olimex_Module.ino.cpp.o: In function `setup()':
<my sketch path>/Olimex_Module/Olimex_Module.ino:38: undefined reference to `TwoWire::onReceive(void (*)(int))'
<my sketch path>/Olimex_Module/Olimex_Module.ino:38: undefined reference to `TwoWire::onRequest(void (*)())'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board OLIMEX ESP32-PoE.
Given that this is example code, I'm not sure how it could be failing. Maybe it's not reading the ESP32 wire library correctly?
Any help would be greatly appreciated.
aahmed7
Re: I2C Slave Library Not Working
Postby aahmed7 » Sun Apr 10, 2022 8:06 am
You need to install the latest development branch for this to work.
Check the following:
https://docs.espressif.com/projects/ard ... rduino-ide
You need to add the Development release link in the arduino ide boards.json and install the release 2.0.1-rc1 or later as these methods were added in this release. check the tag here:
https://github.com/espressif/arduino-es ... 041acce830
Users browsing this forum: No registered users and 47 guests
