huge variations using two concurrent ISR in ESP32
mkeyno
Postby mkeyno » Thu Jan 27, 2022 1:36 am
I've tried to use a pair of proximity sensors for measuring two identical motor speed I used the esp32, with double ISR and counting the duration between puless however, the plot shows when motor speeds are low the calculation nearly each other and converge but when motor speed increases the calculation for both motors have huge variations and diverge since high speed means a high number of interrupt triggers and HW triggers can happen both without any priority
this is my code
```cpp
#include "driver/gpio.h"
//PULSE INPUT 0
int RPM_0_RESET = 0;
//portMUX_TYPE synch = portMUX_INITIALIZER_UNLOCKED;
#define PULSE_IN_0_PIN 15 //25-G1
volatile double pulseTime_0, lastTime_0;
volatile double pulse_freq_0;
void ICACHE_RAM_ATTR isr_pulse_0() {
//used to measure time between pulses.
//portENTER_CRITICAL(&synch);
lastTime_0 = pulseTime_0;
pulseTime_0 = micros();
pulse_freq_0 = (pulseTime_0 - lastTime_0);
//portEXIT_CRITICAL(&synch);
int RPM_1_RESET = 0;
#define PULSE_IN_1_PIN 25 //25-G1
volatile double pulseTime_1, lastTime_1;
volatile double pulse_freq_1;
void ICACHE_RAM_ATTR isr_pulse_1() {
lastTime_1 = pulseTime_1;
pulseTime_1 = micros();
pulse_freq_1 = (pulseTime_1 - lastTime_1);
//SEQUENCER
#define telem_time_interval 200 //Time in ms
unsigned long telem_time = 0;
delay(2000);
//Serial
//PULSE INPUT 0 - RPM FEEDBACK
pinMode(PULSE_IN_0_PIN, INPUT);
//attachInterrupt(PULSE_IN_0_PIN, isr_pulse_0, FALLING);
pinMode(PULSE_IN_1_PIN, INPUT);
if (millis() > telem_time + telem_time_interval)
detachInterrupt(PULSE_IN_0_PIN);
detachInterrupt(PULSE_IN_1_PIN);
Serial.print(6000000/pulse_freq_0);
Serial.print(",");
Serial.println(6000000/pulse_freq_1);
RPM_0_RESET++; //increment reset value
RPM_1_RESET++;
if (RPM_0_RESET > 5) {
pulse_freq_0 = 0.0;
RPM_0_RESET = 0;
if (RPM_1_RESET > 5) {
pulse_freq_1 = 0.0;
RPM_1_RESET = 0;
telem_time = millis();
attachInterrupt(PULSE_IN_0_PIN, isr_pulse_0, RISING);
attachInterrupt(PULSE_IN_1_PIN, isr_pulse_1, RISING);
Users browsing this forum: No registered users and 19 guests
