Guru Meditation Error: Core 1 panic'ed (LoadStoreError) with ESP32 Cam Freenove
superneyluj
Postby superneyluj » Sun Jan 29, 2023 7:10 pm
Hi everyone, I’m trying to process object detection on ESP-32 Cam Wrover.
After uploading the Arduino Library on the Arduino IDE and runing the “esp32_cam” sketch from the examples (from Edge Impulse), I get this error :
Guru Meditation Error: Core  1 panic'ed (LoadStoreError). Exception was unhandled.
Core 1 register dump:
PC      : 0x400df772  PS      : 0x00060430  A0      : 0x80100f75  A1      : 0x3ffb1c60
A2      : 0x3ffc8784  A3      : 0x40000044  A4      : 0x000003c0  A5      : 0x00000010
A6      : 0x00000008  A7      : 0x3ffc4d64  A8      : 0x00000000  A9      : 0x00000002
A10     : 0x00000072  A11     : 0x40000044  A12     : 0x00000030  A13     : 0x000378c0
A14     : 0x00038400  A15     : 0x00000000  SAR     : 0x00000000  EXCCAUSE: 0x00000003
EXCVADDR: 0x40000044  LBEG    : 0x40089854  LEND    : 0x40089870  LCOUNT  : 0x00000000
ELF file SHA256: 0000000000000000
Backtrace: 0x400df772:0x3ffb1c60 0x40100f72:0x3ffb1c80 0x40061b1b:0x3ffb1ca0 0x400e4823:0x3ffb1d20 0x400df6d5:0x3ffb1de0 0x400df7d9:0x3ffb1e10 0x400d2478:0x3ffb1e50 0x400d3173:0x3ffb1e70 0x400dba85:0x3ffb1fb0 0x4008c44e:0x3ffb1fd0
I put some serial.print in my code and the one called "error" didnt appear.
Here is my code :
/* Edge Impulse Arduino examples
 * Copyright (c) 2022 EdgeImpulse Inc.
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
 * SOFTWARE.
/* Includes ---------------------------------------------------------------- */
 * SOFTWARE.
#include <Clem_gro-project-1_inferencing.h>
#include "edge-impulse-sdk/dsp/image/image.hpp"
#include "esp_camera.h"
// Select camera model - find more camera models in camera_pins.h file here
// https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_AI_THINKER // Has PSRAM
#if defined(CAMERA_MODEL_ESP_EYE)
#define PWDN_GPIO_NUM    -1
#define RESET_GPIO_NUM   -1
#define XCLK_GPIO_NUM    4
#define SIOD_GPIO_NUM    18
#define SIOC_GPIO_NUM    23
#define Y9_GPIO_NUM      36
#define Y8_GPIO_NUM      37
#define Y7_GPIO_NUM      38
#define Y6_GPIO_NUM      39
#define Y5_GPIO_NUM      35
#define Y4_GPIO_NUM      14
#define Y3_GPIO_NUM      13
#define Y2_GPIO_NUM      34
#define VSYNC_GPIO_NUM   5
#define HREF_GPIO_NUM    27
#define PCLK_GPIO_NUM    25
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM     32
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
#else
#error "Camera model not selected"
#endif
/* Constant defines -------------------------------------------------------- */
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS           320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS           240
#define EI_CAMERA_FRAME_BYTE_SIZE                 3
/* Private variables ------------------------------------------------------- */
static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
static bool is_initialised = false;
uint8_t *snapshot_buf; //points to the output of the capture
static camera_config_t camera_config = {
    .pin_pwdn = PWDN_GPIO_NUM,
    .pin_reset = RESET_GPIO_NUM,
    .pin_xclk = XCLK_GPIO_NUM,
    .pin_sscb_sda = SIOD_GPIO_NUM,
    .pin_sscb_scl = SIOC_GPIO_NUM,
    .pin_d7 = Y9_GPIO_NUM,
    .pin_d6 = Y8_GPIO_NUM,
    .pin_d5 = Y7_GPIO_NUM,
    .pin_d4 = Y6_GPIO_NUM,
    .pin_d3 = Y5_GPIO_NUM,
    .pin_d2 = Y4_GPIO_NUM,
    .pin_d1 = Y3_GPIO_NUM,
    .pin_d0 = Y2_GPIO_NUM,
    .pin_vsync = VSYNC_GPIO_NUM,
    .pin_href = HREF_GPIO_NUM,
    .pin_pclk = PCLK_GPIO_NUM,
    //XCLK 20MHz or 10MHz for OV2640 double FPS (Experimental)
    .xclk_freq_hz = 20000000,
    .ledc_timer = LEDC_TIMER_0,
    .ledc_channel = LEDC_CHANNEL_0,
    .pixel_format = PIXFORMAT_JPEG, //YUV422,GRAYSCALE,RGB565,JPEG
    .frame_size = FRAMESIZE_QVGA,    //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
    .jpeg_quality = 12, //0-63 lower number means higher quality
    .fb_count = 1,       //if more than one, i2s runs in continuous mode. Use only with JPEG
    .fb_location = CAMERA_FB_IN_PSRAM,
    .grab_mode = CAMERA_GRAB_WHEN_EMPTY,
/* Function definitions ------------------------------------------------------- */
bool ei_camera_init(void);
void ei_camera_deinit(void);
bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) ;
* @brief      Arduino setup function
void setup()
    //comment out the below line to start inference immediately after upload
    while (!Serial);
    Serial.println("Edge Impulse Inferencing Demo");
    if (ei_camera_init() == false) {
        ei_printf("Failed to initialize Camera!\r\n");
    else {
        ei_printf("Camera initialized\r\n");
    ei_printf("\nStarting continious inference in 2 seconds...\n");
    ei_sleep(2000);
* @brief      Get data and run inferencing
* @param[in]  debug  Get debug info if true
void loop()
    // instead of wait_ms, we'll wait on the signal, this allows threads to cancel us...
    if (ei_sleep(5) != EI_IMPULSE_OK) {
        return;
    snapshot_buf = (uint8_t*)malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE);
    // check if allocation was successful
    if(snapshot_buf == nullptr) {
        ei_printf("ERR: Failed to allocate snapshot buffer!\n");
        return;
    ei::signal_t signal;
    signal.total_length = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT;
    signal.get_data = &ei_camera_get_data;
    if (ei_camera_capture((size_t)EI_CLASSIFIER_INPUT_WIDTH, (size_t)EI_CLASSIFIER_INPUT_HEIGHT, snapshot_buf) == false) {
        ei_printf("Failed to capture image\r\n");
        free(snapshot_buf);
        return;
    // Run the classifier
    ei_impulse_result_t result = { 0 };
    EI_IMPULSE_ERROR err = run_classifier(&signal, &result, debug_nn);
    if (err != EI_IMPULSE_OK) {
        ei_printf("ERR: Failed to run classifier (%d)\n", err);
        return;
    // print the predictions
    ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n",
                result.timing.dsp, result.timing.classification, result.timing.anomaly);
#if EI_CLASSIFIER_OBJECT_DETECTION == 1
    bool bb_found = result.bounding_boxes[0].value > 0;
    for (size_t ix = 0; ix < result.bounding_boxes_count; ix++) {
        auto bb = result.bounding_boxes[ix];
        if (bb.value == 0) {
            continue;
        ei_printf("    %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\n", bb.label, bb.value, bb.x, bb.y, bb.width, bb.height);
    if (!bb_found) {
        ei_printf("    No objects found\n");
#else
    for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
        ei_printf("    %s: %.5f\n", result.classification[ix].label,
                                    result.classification[ix].value);
#endif
#if EI_CLASSIFIER_HAS_ANOMALY == 1
        ei_printf("    anomaly score: %.3f\n", result.anomaly);
#endif
    free(snapshot_buf);
 * @brief   Setup image sensor & start streaming
 * @retval  false if initialisation failed
bool ei_camera_init(void) {
    if (is_initialised) return true;
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
    //initialize the camera
    esp_err_t err = esp_camera_init(&camera_config);
    if (err != ESP_OK) {
      Serial.printf("Camera init failed with error 0x%x\n", err);
      return false;
    sensor_t * s = esp_camera_sensor_get();
    // initial sensors are flipped vertically and colors are a bit saturated
    if (s->id.PID == OV3660_PID) {
      s->set_vflip(s, 1); // flip it back
      s->set_brightness(s, 1); // up the brightness just a bit
      s->set_saturation(s, 0); // lower the saturation
#if defined(CAMERA_MODEL_M5STACK_WIDE)
    s->set_vflip(s, 1);
    s->set_hmirror(s, 1);
#elif defined(CAMERA_MODEL_ESP_EYE)
    s->set_vflip(s, 1);
    s->set_awb_gain(s, 1);
#endif
    is_initialised = true;
    return true;
 * @brief      Stop streaming of sensor data
void ei_camera_deinit(void) {
    //deinitialize the camera
    esp_err_t err = esp_camera_deinit();
    if (err != ESP_OK)
        ei_printf("Camera deinit failed\n");
        return;
    return;
 * @brief      Capture, rescale and crop image
 * @param[in]  img_width     width of output image
 * @param[in]  img_height    height of output image
 * @param[in]  out_buf       pointer to store output image, NULL may be used
 *                           if ei_camera_frame_buffer is to be used for capture and resize/cropping.
 * @retval     false if not initialised, image captured, rescaled or cropped failed
bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) {
    bool do_resize = false;
    if (!is_initialised) {
        ei_printf("ERR: Camera is not initialized\r\n");
        return false;
    camera_fb_t *fb = esp_camera_fb_get();
    if (!fb) {
        ei_printf("Camera capture failed\n");
        return false;
   bool converted = fmt2rgb888(fb->buf, fb->len, PIXFORMAT_JPEG, snapshot_buf);
   ei_printf("ERROR!\n");
   esp_camera_fb_return(fb);
   if(!converted){
       ei_printf("Conversion failed\n");
       return false;
    if ((img_width != EI_CAMERA_RAW_FRAME_BUFFER_COLS)
        || (img_height != EI_CAMERA_RAW_FRAME_BUFFER_ROWS)) {
        do_resize = true;
    if (do_resize) {
        ei::image::processing::crop_and_interpolate_rgb888(
        out_buf,
        EI_CAMERA_RAW_FRAME_BUFFER_COLS,
        EI_CAMERA_RAW_FRAME_BUFFER_ROWS,
        out_buf,
        img_width,
        img_height);
    return true;
static int ei_camera_get_data(size_t offset, size_t length, float *out_ptr)
    // we already have a RGB888 buffer, so recalculate offset into pixel index
    size_t pixel_ix = offset * 3;
    size_t pixels_left = length;
    size_t out_ptr_ix = 0;
    while (pixels_left != 0) {
        out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix + 2];
        // go to the next pixel
        out_ptr_ix++;
        pixel_ix+=3;
        pixels_left--;
    // and done!
    return 0;
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_CAMERA
#error "Invalid model for current sensor"
#endif
if anyone have an idea ill take it. Im in dead end for now.
superneyluj
Re: Guru Meditation Error: Core 1 panic'ed (LoadStoreError) with ESP32 Cam Freenove
Postby superneyluj » Mon Jan 30, 2023 5:58 pm
I tried finding the error with ESP Exception Decoder and i got this :
0x400d24ab: ei_camera_capture(unsigned int, unsigned int, unsigned char*) at C:\Users\cleme\Documents\Arduino\esp32_camera/esp32_camera.ino line 294
0x400d31c6: loop() at C:\Users\cleme\Documents\Arduino\esp32_camera/esp32_camera.ino line 155
0x400dbb05: loopTask(void*) at C:\Users\cleme\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32\main.cpp line 23
0x4008c44e: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c line 143
PC: 0x400df7f2: _rgb_write at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/esp32-camera/conversions/to_bmp.c line 109
Decoding stack results
0x40100ffe: _jpg_write at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/esp32-camera/conversions/esp_jpg_decode.c line 67
0x400e48a3: esp_jpg_decode at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/esp32-camera/conversions/esp_jpg_decode.c line 113
0x400df755: jpg2rgb888 at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/esp32-camera/conversions/to_bmp.c line 137
0x400df859: fmt2rgb888 at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/components/esp32-camera/conversions/to_bmp.c line 187
Users browsing this forum: No registered users and 53 guests
