ESP32 web server; creates WiFi channel but does not load web pages
Posted: Fri Feb 03, 2023 6:26 pm
by campinLOU
ESP32 web server; creates WiFi channel but does not load web pages; changing channel did not fix problem; changing IP address, still not loading web pages on either cell phone or laptop; Arduino 1.8.19, board manager esp32 2.0.5; ESP32-WROOM-DA Module, default 4MB, 240MHz, 4MB, core 1
11:51:57.734 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
11:51:57.734 -> configsip: 0, SPIWP:0xee
11:51:57.734 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
11:51:57.734 -> mode:DIO, clock div:1
11:51:57.734 -> load:0x3fff0030,len:1344
11:51:57.734 -> load:0x40078000,len:13864
11:51:57.734 -> load:0x40080400,len:3608
11:51:57.767 -> entry 0x400805f0
11:51:58.000 -> [1][V][WiFiServer.h:42] WiFiServer(): WiFiServer::WiFiServer(port=⸎brrrJj
11:51:58.000 -> [1][V][WebServer.cpp:87] WebServer(): WebServer::Webserver(port=80)
11:51:58.034 -> [7][D][esp32-hal-cpu.c:244] setCpuFrequencyMhz(): PLL: 480 / 2 = 240 Mhz, APB: 80000000 Hz
11:51:58.034 ->
11:51:58.034 -> [*] Creating AP
11:51:58.167 -> Listing directory: /
11:51:58.352 -> FILE: app.js SIZE: 13101
11:51:58.352 -> FILE: favicon.ico SIZE: 4286
11:51:58.352 -> FILE: atom196.png SIZE: 5469
11:51:58.352 -> FILE: styles.css SIZE: 31
11:51:58.352 -> FILE: index.htm SIZE: 10733
11:51:58.352 -> [307][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 0 - WIFI_READY
11:51:58.394 -> [395][WiFiGeneric.cpp:1354] setDualAntennaConfig(): TX Antenna will be automatically selected
11:51:58.401 -> [395][V][WiFiGeneric.cpp:390] _arduino_event_cb(): AP Started
11:51:58.438 -> [396][V][WiFiGeneric.cpp:97] set_esp_interface_ip(): Configuring SoftAP static IP: 192.168.55.1, MASK: 255.255.255.0, GW: 192.168.55.1
11:51:58.438 -> [399][D][WiFiGeneric.cpp:929] _eventCallback(): Arduino Event: 10 - AP_START
11:51:58.438 -> [418][V][WiFiGeneric.cpp:143] set_esp_interface_ip(): SoftAP: 192.168.55.1 | Gateway: 192.168.55.1 | DHCP Start: 0.0.0.0 | Netmask: 255.255.255.0
11:51:58.438 -> [431][V][WiFiGeneric.cpp:190] set_esp_interface_ip(): DHCP Server Range: 192.168.55.2 to 192.168.55.12
11:52:00.463 -> [+] AP Created with IP Gateway 192.168.55.1
11:52:00.463 -> [2442][V][RequestHandlersImpl.h:73] StaticRequestHandler(): StaticRequestHandler: path=/index.htm uri=/ isFile=1, cache_header=max-age=86400
11:52:00.463 ->
11:52:00.463 -> [2446][V][RequestHandlersImpl.h:73] StaticRequestHandler(): StaticRequestHandler: path=/index.htm uri=/index.htm isFile=1, cache_header=max-age=86400
11:52:00.547 ->
11:52:00.547 -> [2506][V][RequestHandlersImpl.h:73] StaticRequestHandler(): StaticRequestHandler: path=/favicon.ico uri=/favicon.ico isFile=1, cache_header=max-age=86400
11:52:00.547 ->
11:52:00.547 -> [2510][V][RequestHandlersImpl.h:73] StaticRequestHandler(): StaticRequestHandler: path=/css/styles.css uri=/css/styles.css isFile=1, cache_header=max-age=86400
11:52:00.547 ->
11:52:00.622 -> [2569][V][RequestHandlersImpl.h:73] StaticRequestHandler(): StaticRequestHandler: path=/js/app.js uri=/js/app.js isFile=1, cache_header=max-age=86400
11:52:00.622 ->
11:52:00.622 -> [2573][V][RequestHandlersImpl.h:73] StaticRequestHandler(): StaticRequestHandler: path=/images/atom196.png uri=/images/atom196.png isFile=1, cache_header=max-age=86400
11:52:00.622 ->
11:52:00.622 -> HTTP server started
11:52:00.729 -> .........................................
    #include <FastLED.h>
    #if defined(FASTLED_VERSION) && (FASTLED_VERSION < 3003000)
    #warning "Requires FastLED 3.3 or later; check github for latest code."
    #endif
    #include <WiFi.h>
    #include <WebServer.h>
    #include <FS.h>
    #include <SPIFFS.h>
    #include <EEPROM.h>
    WebServer webServer(80);
    const char* ssid           = "JailCell";
    const char* password       = "1234567890";
    const int   channel        = 10;
    const bool  hide_SSID      = false;
    IPAddress local_ip(192,168,55,1);
    IPAddress gateway(192,168,55,1);
    IPAddress subnet(255,255,255,0);
    const int led = 5;
    uint8_t autoplay = 0;
    uint8_t autoplayDuration = 10;
    unsigned long autoPlayTimeout = 0;
    uint8_t currentPatternIndex = 0;
    uint8_t gHue = 0;
    uint8_t power = 1;
    uint8_t brightness = 8;
    uint8_t speed = 30;
    uint8_t cooling = 50;
    uint8_t sparking = 120;
    CRGB solidColor = CRGB::Blue;
    uint8_t cyclePalettes = 0;
    uint8_t paletteDuration = 10;
    uint8_t currentPaletteIndex = 0;
    unsigned long paletteTimeout = 0;
    #define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
    #define DATA_PIN    18
    #define LED_TYPE    WS2812
    #define COLOR_ORDER GRB
    #define NUM_STRIPS  1
    #define NUM_LEDS_PER_STRIP 64
    #define NUM_LEDS NUM_LEDS_PER_STRIP * NUM_STRIPS
    CRGB leds[NUM_LEDS];
    #define MILLI_AMPS         1600
    #define FRAMES_PER_SECOND  120
    #include "patterns.h"
    #include "field.h"
    #include "fields.h"
    void listDir(fs::FS &fs, const char * dirname, uint8_t levels) {
      Serial.printf("Listing directory: %s\n", dirname);
      File root = fs.open(dirname);
      if (!root) {
        Serial.println("Failed to open directory");
        return;
      if (!root.isDirectory()) {
        Serial.println("Not a directory");
        return;
      File file = root.openNextFile();
      while (file) {
        if (file.isDirectory()) {
          Serial.print("  DIR : ");
          Serial.println(file.name());
          if (levels) {
            listDir(fs, file.name(), levels - 1);
        } else {
          Serial.print("  FILE: ");
          Serial.print(file.name());
          Serial.print("  SIZE: ");
          Serial.println(file.size());
    void setup() {
      pinMode(led, OUTPUT);
      digitalWrite(led, 1);
      Serial.begin(115200);
      Serial.println("\n[*] Creating AP");
      SPIFFS.begin();
      listDir(SPIFFS, "/", 1);
      WiFi.mode(WIFI_AP);
      WiFi.softAPConfig(local_ip, gateway, subnet);
      WiFi.softAP(ssid, password, channel, hide_SSID);
      delay(2000);  // to avoid crash on WiFi connection
      Serial.print("[+] AP Created with IP Gateway ");
      Serial.println(WiFi.softAPIP());
      setupWeb();
      FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
      FastLED.setMaxPowerInVoltsAndMilliamps(5, MILLI_AMPS);
      FastLED.setBrightness(brightness);
      autoPlayTimeout = millis() + (autoplayDuration * 1000);
    void setupWeb() {
      webServer.on("/all", HTTP_GET, []() {
        digitalWrite(led, 0);
        String json = getFieldsJson(fields, fieldCount);
        webServer.send(200, "text/json", json);
      webServer.on("/fieldValue", HTTP_GET, []() {
        String name = webServer.arg("name");
        String value = getFieldValue(name, fields, fieldCount);
        webServer.send(200, "text/json", value);
      webServer.on("/fieldValue", HTTP_POST, []() {
        String value = webServer.arg("value");
        String newValue = setFieldValue(name, value, fields, fieldCount);
        webServer.send(200, "text/json", newValue);
      webServer.serveStatic("/", SPIFFS, "/index.htm", "max-age=86400");
      webServer.serveStatic("/index.htm", SPIFFS, "/index.htm", "max-age=86400");
      webServer.serveStatic("/favicon.ico", SPIFFS, "/favicon.ico", "max-age=86400");
      webServer.serveStatic("/css/styles.css", SPIFFS, "/css/styles.css", "max-age=86400");
      webServer.serveStatic("/js/app.js", SPIFFS, "/js/app.js", "max-age=86400");
      webServer.serveStatic("/images/atom196.png", SPIFFS, "/images/atom196.png", "max-age=86400");
      webServer.begin();
      Serial.println ( "HTTP server started" );
    void handleWeb() {
      static bool webServerStarted = false;
      // check for connection
      if ( WiFi.status() == WL_CONNECTED ) {
        if (!webServerStarted) {
          // turn off the board's LED when connected to wifi
          Serial.println();
          Serial.println("WiFi connected");
          Serial.print("IP address: ");
          webServerStarted = true;
          setupWeb();
        webServer.handleClient();
      } else {
        // blink the board's LED while connecting to wifi
        static uint8_t ledState = 0;
        EVERY_N_MILLIS(125) {
          ledState = ledState == 0 ? 1 : 0;
          digitalWrite(led, ledState);
          Serial.print (".");
    void loop()
      handleWeb();
      if (power == 0) {
        fill_solid(leds, NUM_LEDS, CRGB::Black);
      else {
        patterns[currentPatternIndex].pattern();
        EVERY_N_MILLISECONDS(40) {
          nblendPaletteTowardPalette(currentPalette, targetPalette, 8);
          gHue++;
        if (autoplay == 1 && (millis() > autoPlayTimeout)) {
          nextPattern();
        if (cyclePalettes == 1 && (millis() > paletteTimeout)) {
          nextPalette();
          paletteTimeout = millis() + (paletteDuration * 1000);
      FastLED.show();
      FastLED.delay(1000 / FRAMES_PER_SECOND);
    void nextPattern()
      currentPatternIndex = (currentPatternIndex + 1) % patternCount;
    void nextPalette()
      currentPaletteIndex = (currentPaletteIndex + 1) % paletteCount;
      targetPalette = palettes[currentPaletteIndex];
