Update on get.exe SSLError
To avoid the get.exe SSLError, just downloaded the xtensa GCC toolchain from here and put in tools folder:
http://domoticx.com/sdk-esp32-xtensa-ar ... toolchain/
unzip and put it in the tools folder e.g:
[user]\Documents\Arduino\hardware\espressif\esp32\tools
You might have to delete Arduino preferences i.e the Arduino15 folder: [user]\AppData\Local\Arduino15 (I needed this)
Now Arduino IDE should start up.
Select tools menu and select target platform "ESP32 dev module" (cos I have it)
BTW selecting the "boards Manager" causes another Java SSL exception.
Trying blink demo:
#define led 2
void setup() {
pinMode(led, OUTPUT);
void loop() {
digitalWrite(led, HIGH);
delay(500);
digitalWrite(led, LOW);
delay(500);
So now I get a compile - the toolchain runs, but simple blink -> "Error compiling for board ESP32 Dev Module"
Nice error message, no indication why, where etc - could it be related to just copying the toolchain, is there some additional setup?
GCC environment, target CPU/Board header files setup perhaps?
All in all, very messy experience under windows 10.
Any help really appreciated.
