Disable OFFER_Router
sorenhl
Postby sorenhl » Fri Jun 08, 2018 9:39 pm
I am trying to port a esp8266 project to ESP32, but i am facing issues with one command:
uint8 mode = 0;
wifi_softap_set_dhcps_offer_option(OFFER_ROUTER, &mode);
It does so iPhones can still surf the internet while being connected to the AP.
It seems like the functionality is inside "apps/dhcpserver.h", but I cannot really figure out how to use the dhcps_set_option_info.
Any idea how to do this now? I have been trying and failing for hours, so any help would be greatly appreciated.
/Søren
WiFive
Re: Disable OFFER_Router
Postby WiFive » Sat Jun 09, 2018 9:47 am
Try
uint8_t val = 0;
tcpip_adapter_dhcps_option(TCPIP_ADAPTER_OP_SET, ROUTER_SOLICITATION_ADDRESS, &val, sizeof(dhcps_offer_t));
sorenhl
Postby sorenhl » Sat Jun 09, 2018 8:45 pm
The code you posted works perfect, thank you so much!
If anybody else is trying this, remember to stop, apply line, start the dhcp server for it to work :D
phatpaul
Postby phatpaul » Fri Nov 02, 2018 6:17 pm
Elsewhere on the web people say to disable dhcp option 3 and option 6.
https://superuser.com/questions/596053/ ... in-openwrt
But you say to use ROUTER_SOLICITATION_ADDRESS which is option 32.
So is it option 3 or 32?
I'm going to also disable option 3 and 6 just to be sure.
Where is the documentation for this?
I only found:
https://www.esp8266.com/viewtopic.php?t=1798
phatpaul
Postby phatpaul » Fri Nov 02, 2018 7:10 pm
Nevermind, this IDF code is a mess...
It looks like it actually prevents sending ROUTER option 3, even though the API incorrectly uses ROUTER_SOLICITATION_ADDRESS (32) as a flag for that functionality.
But should we not send option 3, or send it with an invalid IP of 0.0.0.0?
Also, by setting
uint8_t opt_val = 0; // don't supply a dns server via dhcps
ESP_ERROR_CHECK(tcpip_adapter_dhcps_option(TCPIP_ADAPTER_OP_SET, TCPIP_ADAPTER_DOMAIN_NAME_SERVER, &opt_val, 1));
It is still sending option 6 - dns server. But it is just sending it's own IP. See
https://github.com/espressif/esp-idf/bl ... ver.c#L344
But shouldn't we be able to prevent sending the option 6 entirely?
Return to “ESP32 Arduino”
Users browsing this forum: No registered users and 6 guests
