What is happening with my interrupt....
Posted: Tue Aug 07, 2018 4:27 am
by Don Warr911
I am using 2 input pins tied together as interrupts, to catch rising and falling VPW. rising starts one timer falling starts 2 timer.. This gives me the pulse width times... Using Arduino for programming. Example of interrupts =
void CountH()
digitalWrite(txPin, HIGH);
TrigL = false;
TrigH = true;
THstart = micros();
TLstop = micros();
TLtime = (TLstop - TLstart);
YY = YY + 1;
void CountL()
digitalWrite(txPin, LOW);
TrigH = false;
TrigL = true;
TLstart = micros();
THstop = micros();
THtime = (THstop - THstart);
XX = XX + 1;
this works good ONLY if I use a loop outside the Above interrupts.. I put the time into an array DHigh(YY) = TLtime, and DLow(XX) = THtime... My Problem = If I add the line DHtime[XX] = THtime IN the above interrupts, instead of in an outside loop, the times are not correct... (It seems ESP32 interrupts don't do values to arrays).. Any response would be appreciated... Thanks...
Re: What is happening with my interrupt....
Posted: Tue Aug 07, 2018 5:12 am
by ESP_Angus
Moderator's note: moved to Arduino forum.
Are you able to please post a full (compile-able) Arduino sketch that demonstrates the problem you're seeing? It's not possible to see the full picture from the part posted here.
Posted: Tue Aug 07, 2018 7:09 am
by Don Warr911
Moderator Asked me To Post the code...
This WILL as it is now, read an OBDII J1850 VPW Port, It will also tell you all information from the Headers,, Source,, Target and Data..
Unlike the ELM326 It gives DETALs... AND shows where the 200us SOF starts...
It uses 2 interupts... IF I COULD ADD THIS **> DY[YY] = TLtime; <** ONE LINE TO THE CountH() INTERRUPT, AND **> DX[XX] = THtime; <** LINE
TO THE CountL() INTERRUPT I COULD GET RID OF THE HOLE > void loop() < routine...
But if I add them the timing gets screwed up...
int Led1 = 2;      // GPIO2 of ESP32   // On Board
int txPin = 22;    // GPIO22 of ESP output
int rxPinH = 32;   // GPIO32 of ESP input Interrupt High Pulse
int rxPinL = 33;   // GPIO32 of ESP input Interrupt Low Pulse
int ButtonPin = 4; // GPIO4 of ESP output
int ButtonState;
boolean TrigH = false;
boolean TrigL = false;
int THstart = 0;
int THstop = 0;
int THtime = 0;
int TLstart = 0;
int TLstop = 0;
int TLtime = 0;
int XX = 0;
int YY = 0;
int DX[3000];  // High
int DY[3000];  // Low
int SOF[100];  // Start of Frame, Holds the ByteCount
int bCount = 0;
int MyBit[9];
byte Mybyte = 0;
byte ByteArray[3000];
int ByteCount = 0;
int SOFcount = 0;
int i;
int j;
String IsThisHeader = "No";
int NumMessages = 0;
boolean WhileStop = false;
void setup()
  pinMode(Led1, OUTPUT);
  pinMode( txPin, OUTPUT );
  pinMode( rxPinH,INPUT);
  pinMode( rxPinL,INPUT);
  pinMode(ButtonPin, INPUT_PULLUP);
  digitalWrite(Led1, LOW);
  attachInterrupt(digitalPinToInterrupt(rxPinH), CountH,RISING);
  attachInterrupt(digitalPinToInterrupt(rxPinL), CountL,FALLING);
  Serial.begin(115200);
  delay(4000);
  Serial.println("STARTING");
  digitalWrite(Led1, HIGH);
void loop()
  if (TrigH == true)
    DY[YY] = TLtime;
    TrigH = false;
  if (TrigL == true)
    DX[XX] = THtime;
    TrigL = false;
  ButtonState = digitalRead(ButtonPin);
  if (ButtonState == 0)
     detachInterrupt(rxPinH);
     detachInterrupt(rxPinL);
     ProcessPulses();
void CountH()
  TrigL = false;
  TrigH = true;
  THstart = micros();
  TLstop = micros();
  //>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> THIS is where I want to add the LINE-  DY[YY] = TLtime;
  YY = YY + 1;
void CountL()
  TrigH = false;
  TrigL = true;
  TLstart = micros();
  THstop = micros();
 //>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> THIS is where I want to add the LINE-  DX[XX] = THtime;
  XX = XX + 1;
void ProcessPulses()
  Serial.println("Processing Pulses");
  Serial.println(XX);
  Serial.println(YY);
  Serial.println();
  for (int i=1; i <= XX; i++)
      if (DX[i] > 185 and DX[i] < 220)  //Header
        Serial.print("-");
        ByteCount = ByteCount + 1;
        ByteArray[ByteCount] = 45;
        SOF[SOFcount] = ByteCount;
        SOFcount = SOFcount + 1;     // count starts at 0
        IsThisHeader = "Yes";
      else
      if (IsThisHeader == "No")          // Not a Header, Put 8bits to make Byte
        //Serial.print( DX[i]);
        //Serial.print(" ");
        if(DY[i] > 110 and DY[i] < 140)  //-128
            bCount = bCount + 1;
            MyBit[bCount] = 1;
        if(DY[i] > 45 and DY[i] < 70 )   //-64
            MyBit[bCount] = 0;
        if(DX[i] > 110 and DX[i] < 150)  //+128
            MyBit[bCount] = 0;
        if(DX[i] > 45 and DX[i] < 85 )   //+64
            MyBit[bCount] = 1;
        if(bCount == 8)  // bits
            //Mybyte = (MyBit[1] << 3) | (MyBit[2] << 2) | (MyBit[3] << 1) | (MyBit[4] << 0);   //= 8
            Mybyte = (MyBit[1] << 7) | (MyBit[2] << 6) | (MyBit[3] << 5) | (MyBit[4] << 4) | (MyBit[5] << 3) | (MyBit[6] << 2) | (MyBit[7] << 1) | (MyBit[8] << 0);
            Serial.print(Mybyte,HEX);
            ByteArray[ByteCount] = Mybyte;
            bCount = 0;
  Serial.println();
  SOFcount = 0;
  for (int i=1; i <= ByteCount; i++)
    if ((ByteArray[i] == 45) and (SOF[SOFcount] == i))     // SOF data starts at 0
      Serial.print("-");
    else
      Serial.print(ByteArray[i],HEX);
  Serial.println();
  PrintData();
  while (1){}
void PrintData()
   i = 0;
   SOFcount = 0;
   NumMessages = 0;
   while (i <= ByteCount)
     i = i + 1;
       Serial.println();
       NumMessages = NumMessages + 1;
       Serial.print(NumMessages);
       Serial.print(") ");
       Serial.print("Found a Header Byte = ");
       i = i + 1;
       Mybyte = ByteArray[i];
       Serial.println(Mybyte,HEX);
       Serial.print("Priority = ");
       Serial.print(bitRead(Mybyte, 7));     // Priority
       Serial.print(bitRead(Mybyte, 6));
       Serial.print(bitRead(Mybyte, 5));
       Serial.print(" | ");
       Serial.print(" Headers = ");         // Num of Headers to follow
       if (bitRead(Mybyte, 4) == 0)
         Serial.print("3");
       else
         Serial.print("1");
       Serial.print(" InFrame = ");         // InFrame
       if (bitRead(Mybyte, 3) == 0)
         Serial.print("Required");
       else
         Serial.print("Not Allowed");
       Serial.print(" Addressinng Mode = ");    // Addressinng Mode
       if (bitRead(Mybyte, 2) == 0)
         Serial.print("Functional Addressing");
       else
         Serial.print("Physical Addressing");
       Serial.print(" | ");                     // Message Type
       Serial.print(" Message Type = ");
       if ((bitRead(Mybyte, 1) == 0) and (bitRead(Mybyte, 0) == 0))  // =00
         Serial.print("0 Data Bytes");
       if ((bitRead(Mybyte, 1) == 0) and (bitRead(Mybyte, 0) == 1))  // =01
         Serial.print("1 Data Bytes");
       if ((bitRead(Mybyte, 1) == 1) and (bitRead(Mybyte, 0) == 0))  // =10
         Serial.print("2 Data Bytes");
       if ((bitRead(Mybyte, 1) == 1) and (bitRead(Mybyte, 0) == 1))  // =11
         Serial.print("3 Data Bytes");
       Serial.print(" = ");
       Serial.print(bitRead(Mybyte, 1));
       Serial.print(bitRead(Mybyte, 0));
       //Header info
       if (bitRead(Mybyte, 4) == 0)   // * 3 byte Header
         Serial.println();
         Serial.print("Source = ");
         Mybyte = ByteArray[i + 2];
         Mybyte = ByteArray[i + 1];
         Serial.print(" Target = ");
       // Message Data
       Serial.print("       Message Data = ");
       j = 3;
       while (WhileStop == false)
         Mybyte = ByteArray[i + j];
         if (Mybyte != 45)
           Serial.print(",");
           j = j + 1;
           if (j > 14)
             WhileStop = true;
         else
          WhileStop = true;
       WhileStop = false;
       Serial.print(" Last Byte is Checksum");
       Serial.println();
Posted: Thu Aug 09, 2018 1:44 am
by ESP_Angus
I'm not certain I see the problem, but I think some of the variables being manipulated or checked in the ISRs will need to be declared "volatile" to ensure the compiler isn't optimizing out accesses to them.
BTW, for the goal you're aiming for (measuring pulse durations), timers in GPIO ISRs are not the best solution on the ESP32 (mostly due to interrupt latency : the ESP32 CPU is a lot more complex than simple 8-bit micros). You might want to consider looking at the RMT ("Remote Control") peripheral, which is designed for actually this purpose (measuring pulses). There is a driver IDF which can be used from Arduino.
There is also an Arduino native driver in development, although it's not merged yet.
