SPIFFS doesn't work anymore
miladgh
Postby miladgh » Wed Nov 07, 2018 4:01 pm
Hey guys,
I'm working with an ESP32 and need to write some files there.
but the problem is, SPIFFS doesn't work anymore.
I used SPIFFS_Test from Examples or this code:
#include "SPIFFS.h"
  if (!SPIFFS.begin(true)) {
    Serial.println("An Error has occurred while mounting SPIFFS");
    return;
  File file = SPIFFS.open("/test.txt", FILE_WRITE);
  if (!file) {
    Serial.println("There was an error opening the file for writing");
    return;
  if (file.print("TEST")) {
    Serial.println("File was written");
    Serial.println("File write failed");
  file.close();
  Serial.println(SPIFFS.exists("/test.txt"));
  Serial.println(SPIFFS.exists("/nonexisting.txt"));
void loop() {}
But I got just "FAILED ERROR."
What could be the reason?
ESP_Sprite
Re: SPIFFS doesn't work anymore
Postby ESP_Sprite » Thu Nov 08, 2018 2:47 am
Moved to the Arduino subforum.
miladgh
Postby miladgh » Thu Nov 08, 2018 9:10 am
I checked the directory and found some files that I created before. I deleted them and it works again!
Users browsing this forum: No registered users and 69 guests
