Technical Parameters of ESP-WROOM-32
Sai Teja
Postby Sai Teja » Tue Nov 13, 2018 1:37 pm
Hi, I are using ESP-WROOM-32 in an application. Please provide the following details regarding ble transmission of ESP-WROOM-32.
1) modulation bandwidth ,
2) frequency channels and
3) data rate.
4) Tx Power
Can we change above parameters programatically? If yes, please tell how to change these values? If no, please tell what are the default values of the parameters?
I am using Arduino Core for ESP-32 for programming.
We need the information quickly, please respond as soon as possible.
Awaiting your reply.
tommeyers
Re: Technical Parameters of ESP-WROOM-32
Postby tommeyers » Tue Nov 13, 2018 2:33 pm
I think *you* need to do some work; begin to reading the technical specifications!
Then post again when you have done that; and post a list of what you have read and if any questions still remain this is a good place to ask for help.
Tom Meyers
IT Professional, Maker
Santiago, Dominican Republic
ESP_Lvxinyue
Postby ESP_Lvxinyue » Wed Nov 14, 2018 11:36 am
3) data rate.
4) Tx Power
For "frequency channels", if you mean changing the channel when ESP32 is advertising, please try to call this function.
TX power can be set by calling this function.
The other two parameters are given by the Bluetooth spec and cannot be changed.
Let me know if you have further questions. Thanks.
Sai Teja
Postby Sai Teja » Thu Nov 15, 2018 2:47 pm
Hi ESP_Lvxinyue,
Thank for your information.
Please tell the default values of modulation bandwidth and datarate.
And regarding frequency channel , you referred function related to starting ble advertisement. I would like to know frequency channel for ble transmission.
Users browsing this forum: No registered users and 6 guests
