All GPIO pins can be i2c?
When I looking for the i2c peripheral pins in some esp32 modules, I couldn't find anything in espressif website. Turns out all the gpio pins can be used as i2c. Is that true? I'm going to design my custom board, and I don't want to change the pins later.
Re: All GPIO pins can be i2c?
Docs are here.
Section 7.1 of the TRM:
You don't want to use any of the pins connecting to the FLASH memory though.The ESP32-C6 chip features 31 GPIO pins. Each pin can be [...] connected to an internal peripheral signal. [...] peripheral input signals can be from any IO pins, and peripheral output signals can be routed to any IO pins.
So, It's true. How about other peripherals? Can they configure to other gpios too?MicroController wrote: ↑Fri Jun 09, 2023 9:21 pmDocs are here.
Section 7.1 of the TRM:You don't want to use any of the pins connecting to the FLASH memory though.The ESP32-C6 chip features 31 GPIO pins. Each pin can be [...] connected to an internal peripheral signal. [...] peripheral input signals can be from any IO pins, and peripheral output signals can be routed to any IO pins.
For the C6, the ADC and the two USB pins are dedicated and not-routable. Aside from that, there's 8 pins that can be controlled by the LP CPU, you want to pay attention to that if you want to use that. Finally, if you want to push SPI to the maximum speed, you can benefit from using the dedicated IO pins for that rather than using random GPIOs.
Users browsing this forum: Baidu [Spider] and 120 guests
